I've been wondering about this light. I've liked Fenix headlights, but they fell behind to Zebralight, Armytek, Spark, Xtar, Crelant...pretty much anything that's created a right angle flashlight. Now Fenix has joined the competition. I do like the lanyard loop. Have you lined up anyone for a review? I'm eager to see how this compares to other lights, particularly my Zebralight H600mkII, Zebralight H52 and Armytek Wizard Pro, and to see if there's anything that makes it special that isn't obvious by looking at pictures.
I want to make sure you know I only have the last three, not all of them. I've wanted some of the other lights, particularly some Spark's, but they weren't introduced when I needed it, and then better things came out.
What you get depends on what you need to get from it. I bought the Wizard Pro first. I loved the even beam pattern for close in work, and the main modes were easy to operate, but the light was heavy, it wasn't easy enough to remove from the harness because of the big tailcap, and it doesn't have much throw, so it wasn't ideal for long distance backpacking. Then I got the H52. That was about as perfect for long distance backpacking as I could dream of due to it being much smaller and lighter, and having the flexibility to use AA's. Then the H600mkII came out, making itself a better competitor to the Wizard Pro than its predecessor. I got one to see how it compared against the Wizard Pro. Both Zebralights have much lower lows, but are way too easy for me to activate turbo when I'm trying to get into the firefly mode. It turns out that there's no clear winner. They both have their own advantages and disadvantages. All three lights share the disadvantage of having nowhere to attach a lanyard, which makes it less than ideal when used as a handheld right angle flashlight. Fenix doesn't have that problem with this new headlamp because they remembered that it's a flashlight too.
Hmmm, that wasn’t quite the clear cut answer I was after, but thanks for your honesty. The ZL’s appeal, but you’re right about the struggle to get firefly, if it’s anything like the SC52 / SC600’s UI.
I saw the HC90vn as well, but the shorter runtime from the boosted current as well as it’s size were deal breakers for me. I just want something small with decent runtimes. IMHO anything over 200-300 lumens for a headlight is overkill.
I was part of the global testing campaign and I took it camping with me last weekend. I am working on a video review of it now and should have it up next week. I own a tiara, a wizard, a spark sg5, and a skilhunt h02. I like the armyteks a bit better but the fenix is very well regulated and all the runtime tests so far seem to jive well with what Fenix claims
I put a H600FW on order. Floody but with a touch of throw, long run times, refined, can double as standing lamp. I don’t think over 300 is overkill in a flood beam. Working outdoors and you’ll want that huge flood. Its very useful!
