Fenix UC52 LED Flashlight - 3100 lumens, 830ft throw - $29
MSRP: $150
Sale is as is!
Mint!
Included: Holster, lanyard, micro-USB charging cable
Product Overview
The Fenix UC52 is a micro-USB rechargeable flashlight built for super-high performance. It is fitted with Cree XHP70 LED, which delivers a maximum output of 3100 lumens at a distance of 830ft (253m). The OLED screen digitally displays current output level and remaining runtime, which allows the user to always be aware of their flashlight’s built-in 7.2/3500mAh Li-ion battery status. Dual side switches separately controls five brightness levels and the two flash modes. The Fenix UC52 rechargeable flashlight also incorporates integrated die casting for excellent heat dissipation and is IP68 rated waterproof and dustproof.
Specifications
  • Max Lumens: 3100
  • Max Beam Distance: 830 feet (253 meters)
  • Max Runtime: 82 hours 30 min.
  • Lighting Modes: 5 brightness levels, strobe, and SOS
  • LED Type: Cree XHP70 LED
  • Size: Length: 6.0″ (153.5mm) Head: 1.7″ (42mm) Body: 1.0″ (26mm)
  • Weight: 9.7 oz. (276g) including battery
  • Battery: Built-in 7.2V/3500mAh Li-ion battery pack
  • Included: Holster, lanyard, micro-USB charging cable
More Information
  • Cree XHP70 LED with lifespan of 50,000 hours
  • Built-in 7.2V/3500mAh Li-ion battery pack with a lifespan of 500 - 800 charging cycles
  • OLED screen digitally displays current output level, battery status and remaining runtime
  • Micro USB charging, inner waterproofing treatment
  • Instant strobe
  • Lockout function avoids accidental activation
  • Digitally regulated output maintains constant brightness
  • Intelligent overheat protection, to protect from high surface temperature
  • Made of aluminum alloy, fitted with stainless steel bezel ring
  • Toughened ultra-clear glass lens with an anti-reflective coating
