Good evening. I have been working on a zy t-08. I have stripped the stock board to use as contact plate for 26mm fet driver flashed with guppdrv. xml u3. 18ga wiring. Braid on springs + heat sink for led.
When I use any mode other than 100% the led flickers like a florecent light that has gone bad. The light output appears to be at the right level. There is also a whine noise from the light. Noise also goes away at 100%.
I have by-passed tail cap - same.
Checked solder connections
Pill is making good contact with body
Using LG HE4 batteries
Getting 4.3A at the tail cap at 100%
Getting .95A at the tail cap at 25%
Using quality amp clamp to test
I have also not soldered #2 star to lock mode selection.
Wire connections
B+ on contact plate to center of bottom side of driver
Led on contact plate to outside ring on bottom side of driver
I am thinking it’s the driver due to problem being in lower modes. I do not have another fet driver to test. Just wondering if there is something else I could be missing.
Could this be the PWM-flicker, one can see by putting the flashlight in parallel with the eyes direction and then synchronously panning around? That could be simply a too low PWM frequency and you are very sensitive to the “flicker”, as i am. If this flicker is unbearable you should dig for a constant current driver, that technology hasn’t any flicker at all.
