fiberglass failures; any ideas?
Figured I’d post here rather than the modified forum.
Tried to make some home-brew G-10 for knife scales. The initial trial using dyed manila folder strips worked well. So I tried to make some black G10 using fiberglass cloth. I used Sudan B black dye [I run a lab so I have access to various biological stains]. Well, long story short, the resin did not harden. I added the recommended amount of liquid hardener, mixed well, but the resin remained soft. BUMMER. So yesterday I ran another trial, this time using methyl blue dye [produces a beautiful indigo blue color]. Again followed mixing directions as per instructions but the resin didn’t harden. Anyone else had a similar experience?
I’m going to try another small trial w/ and w/o the dye to see if that’s what’s stopping the resin from hardening. If I’m successful I’ll post some pics of the dyed G10.
I've had cases where a residue from a certain pen kept epoxy from hardening, so yes, your dye may be the cause of this...
For black, try adding carbon black…
Pyro,
I have carbon black, just have to dissolve it in alcohol. I’ll give it a try. I’m waiting for the test batches to harden to find out if its the resin or the blue dye.
You might have bad resin…it’s common. Even new resin will be damaged if it was frozen during shipment…say in a cold state during Winter in an unheated big-rig, for example. Test your resin without any additives. Epoxy has a short shelf life. I ALWAYS do a sample test to see if it will harden properly. Dry powder type mineral based dye like RIT dye should be compatible.
Actually, it’s the hardener that likes to go bad. An ammonia smell and darkening is a good sign of deteriorating resin. For some reason, a lot of boat builders actually like to use aged hardener…
Did a no dye resin test. The first strip was polyester weave, it saturated well but the resin was still flexible after an hour of drying. A second strip w/ the indigo dye saturated better and was hardening but still soft after an hour.
The hardener appears water clear but I do have another tube so I’ll try that tomorrow. Thanks for all the support.
