Finding a low voltage driver - 0.9v - 3.0v
I need to repair/replace a P60 drop-in for an L2r host. The LED is fine (XR-E), but the driver is simply shot. Having said that though, I will build it from scratch and also use an old XP-G I have lying around.
I have been looking around and the only driver I was able to find is an LD-30 from Int’l Outdoor. Any other suggestions?
There is this 20-mode selectable driver in that voltage range ( single AA ) i have used it in a fiew modded lights i have. http://dx.com/p/3w-5w-20-mode-regulated-circuit-board-for-flashlights-7880
I checked KD, but forgot about DX. Thanks for reminding me DenBarrettSAR!
Any way, I found this other one. It is only 0.8A, but it has the simple 3-modes without any disco options. Also, it’s cheap. This one is taking the lead so far.
The DL-007 model ( you linked to) is another good driver, but only has High, Medium, and a 9HZ strobe mode as mentioned in the specs on the DX page.
Oops. Mistook the 9Hz as the low’s PWM. No biggie. I can handle one disco mode. :slight_smile:
My driver reviews/test are starting to be useful, you can check the list: http://lygte-info.dk/info/indexLedDrivers%20UK.html
