[FINISHED] GorgTech’s 12th Annual BLF Old Lumens Challenge Entry - Machine Made
Hello,
this is going to be a close one, more or less a “last minute Project”.
I spent exactly 1 hour thinking about what I could build with just a few parts I already have at home.
How about a small desk lamp, something I would use for small electronic repairs?
It will use a generic 3W Star LED (which is more than enough for what I want to use it anyway), a DIY 4S 18650 Battery Pack and selfmade 3D printed parts…which right now I´m working on under heavy time pressure.
I hope I can finish it just in time and provide at least a few pictures.
Right now I´m just working on the CAD part of the job and with enough luck, I will have all required parts just in time…
7 Thanks
Ok, time for a update. It was a really close one but I made it just in time.
I was focused this time more on modelling single parts instead of doing CAD Render Pictures because I literally needed every single free minute I had.
All started with a 3W 3500K Star LED which I wanted to use for a different Project and forgot about it. I attached a extra Heat Sink to it with a mix of 2K Glue and Thermal Grease.
The LED is rated at around 3W with a current of 700mA. I tried it out at a current of 600mA and it was bright enough for my needs. It would not overheat either.
I designed the first parts, the Desk Lamp Head and 3D printed them.
Time for other parts. I designed a rectangular base for the Desk Lamp.
And here is the Lid for the base.
After a while I prepared the other required parts. The Desk Lamp Head and the LED insert are a good match.
Since I decided to use a 4S Battery Pack again, I used 4 old 18650 Cells from a broken Power Bank with a failed circuit board. The cells itself tested OK and I precharged them at 4.1V each. I made a holder + insulator for the cells from TPU.
I spot welded the Battery Pack and prepared other parts too.
The lid got a gasket to keep the LED cables as snug as possible.
Several hours of work later, I modelled some more parts and printed them. I had to do some metal work as well :wink:
Here is the first test of the battery pack with the Buck Converter for the LED and a switch. I ordered a 4S BMS but unfortunately this one was delayed and will be delivered after the contest…for now I won´t use the 4S charging circuit. It´s the same variant I used in the last contest, the one which gets really hot. This is why I attached some Heat Sinks to it. The Buck Converter got a extra Heat Sink too, though it is not really required for a current of <2A.
Well, the circuit works like this too, even without a BMS but I will keep a sharp eye on the Battery Level Indicator to prevent the cells from damage. Once I receive the missing part, I will add the BMS and also connect the USB Charger to the Battery Pack.
Time for some Testing. The 3500K LED and the golden filament produce a nice light.
The Battery Level Indicator works too. The rectangular base has a small glitch because of a knot in the filament…but right now I cannot afford to lose more time to print a new one. It does the job for now.
Here are some pictures of the assembled Desk Lamp.
Around 559g is not bad for such a Desk Lamp :wink:
I consider this Project to be finished, it does the job and as soon as I get the 4S BMS, I will install it too.
For a Project which was made in such short time, I can be happy with the results.
The estimated run time of the Desk Lamp with fully charged cells (and max. capacity) is around 4h+, more than enough as a extra helper when soldering and inspecting PCBs.
I will try to make a Video too and post it, hopefully before the timer reaches 0.
Thanks for watching
I like the golden color, it makes the lamp look special and almost like metal. Well done! :+1:
Fantastic idea AND execution!
Thanks guys,
here is a Bonus picture with a boring Beam Shot :wink:
I´m working on a Stop-Motion video now and hope that I can upload and release it just in time.
Verry nice project. I’m glad that you made it in time.
I uploaded a YouTube video, it should be released in about 25 minutes :wink:
Glad you made it in time. Looks nice.
That’s a good looking desk lamp GorgTech!
And the battery level indicator is a nice touch. :+1:
Ah nice, good desk /work lamp to assist your next project!
Cheers🔦
Thanks a lot guys. If I had to build another Desk Lamp like this, I would try to shrink the base even more, just to save material and printing time.
A 2S Battery Pack would have been enough for the 3W LED but I didn´t had a USB charging circuit for it.
I did not want to have a unused hole in the base :wink:
Maybe a next Revision will be born some day.
I waited for the judges to finish their voting, now I can show you what I improved:
I bought fresh 18650 Batteries and built a new Battery Pack, this time a 2S2P in order to have the best results and highest run time.
I also changed the USB charger for a 2S variant :wink:
Why is it a bit heavier now?
Check the Youtube Video to find out :wink:
I extended the lenght since I had more time now to make this lamp even bigger now.
Excellent, congrats… !
You should make an excavator type of lamp… !
