Firemedic
(Firemedic)
1
I see multiple optics for other lights but nothing for the E07. I thought the E07 uses a carclo optic but can’t find anything. Would like a optic with a tighter spot like I see for other lights to give the E07 better throw cause it’s a flood king for sure.
kiriba-ru
(kiriba-ru)
2
Throw is restricted by (tir frint area divided by led die area). You can not just swap optics, for better throw you need bigger tirs or smaller leds. 1sq. mm led die can give reasonable throw in combination with 10mm tirs, 4sq. mm die leds are not able to work as good with tiny tirs.
Carclo dont have any 7-led optics, also carclo uses space more effective (less room between single tirs), and each tir gives slightly better cd/lm.
E07 uses a proprietary Chinese made optic. I’d recommend emailing fireflies your request, perhaps if they receive enough input they can be pressured into commissioning other optic options for it.
Firemedic
(Firemedic)
4
It popularity does seem to be growing. I have 2 and there my current favorite lights. Just would like more beam optic options like the fw3a has.
