First gasoline dedome, does this look right after 7 hours?
This is my first ever gasoline dedome (I’ve had mixed results running the LED to heat up and slicing the dome off).
I looked at tons of pic’s and I always noticed the gas was clean except for the floating dome after ~24 hours. This is 7 hours in, the dome appears to be mostly gone from the emitter but there’s tons of junk [debris] in the gas. This isn’t water, the gas and container were perfectly clean and dry last night. Is all the crap in the gas normal?
Edit: used a dropper to get some of the spots out and rolled them around in my fingers, it appears to be some sort of oil that’s precipitated out of the gas overnight, not part of the dome, maybe gas around here is just dirty? As long as everything is going normal I don’t mind, is this going ok, I’m just concerned.
If you’re using a PET plastic bottle, gasoline will dissolve it rather easily. That may be the stuff you’re seeing, not sure.
Use of a glass container is highly recommended, and I usually pop the dome off after one hour in gasoline.
Looks like droplets of water, which don’t mix with the car fuel.
I’ve never seen any hint of degradation in PET bottles containing car fuel.
But dedoming I did (3 times) in a tiny glass.
Leave it be for at least 24 hours.
…and put a lid on it, or something.
I may be wrong, I remember ruining syringes while moving lighter fluid from one place to another and assumed it would do the same thing to PET.
I don’t think syringes are made of PET.
The rubber plunger is usually not up to solvants anyway.
But who knows what differences there are between Dutch and Korean car fuel? :slight_smile:
They're always adding stuff to gas, ethanol from corn, detergents, lubricants, who knows what. If you buy it right after the station gets a delivery all sorts of gunk from the bottom of the tank gets stirred up.
Those dots you see are moisture, the ethanol in gas is very hygroscopic and it doesn't take much moisture, even ambient moisture, for it to get cloudy like that. I have noticed that it is hard to get a clean dedome using the gasoline method if it's cold out, even if left for an extended period of time. I also think that seasonal gas blends may affect how well it works. If it's been in there for a while I'll bet the dome will just float right off if you lightly touch it, otherwise leave it in there for a while longer then try again.
The dome looks fine but you should clean it with some isopropyl to try and get all the contaminants off the phosphor.
IIRC gasoline degrades pretty quickly when left in the open and in direct sunlight.
I'd agree mostly with above comments. I always use glass (mason jar), always do it at room temperature. I never had problems even at just 2.5 hours - always the dome is loose by then - did many this way, multiple at a time, etc. If the dome is still on, I simply flick it off - touching the side opposite the wires with a toothpick. I wouldn't take chances with any plastics for sure, unless 100% sure no reaction with gas.
I do the full 24 hours to be somewhat certain that no crap still sticks to the dye, like it did the first time, because I was impatient… :slight_smile:
Success, still not sure what the “bubbles” are but after I removed the emitter I lit the gas on fire and it all burned up. Next time I’ll use a glass container.
RMM I bet your wondering how I can put all the parts I get from you together and make working lights when I ask such simple questions lol.
Thanks to everyone, I get to enjoy this hobby more cause you all help me out and answer my questions daily. Much appreciated. The results in my HD2010 are just what I hoped for.
If you saw how my mind works you'd be surprised to see me do much of anything without messing it up! You're doing great, don't sweat it. That's what this place is for!
