I think the distance between the pins in this solution is 2.54mm not 1.27mm..
since there is no other firmware available at this time (and I dont have the ability to build custom firmware), I have no reason to order a 3 pin cables for my prototype TS10V3.
Hopefully the production model will have the pads in standard order R - + and maybe by then there will be some other firmware option.. for now the stock firmware works fine, it just has ceilings set to Turbo, and I changed ceilings without need for reflashing
fwiw, here is a rough measurement of the pin spacing on my gchart 3 pin adapter, 1.5mm:
Compare and contrast TS10V3 and SC53c N (neither LED is stock):
Weights of both lights with LiIon battery and clip. Zebra also works on AA, TS10V3 is 14500 only.
The Zebra has less lux Ripple. The TS10V3 gets brighter, the SC53c N gets dimmer.
its a great feature ![]()
Are the parts of the v1/v2 interchangeable with v3?
Thanks Jon! The new body looks awesome and seems like it will pocket carry so much better; swapping parts is just fun. A new driver in the TS10 is very much welcomed though I will miss the sub lumens.
There are actually some small height differences:
The TS10V3 body is slightly longer than TS10SG.
TS10SG body is slightly longer than TS10V1.
The other parts seem to be equal in length).
fwiw, the TS10V3 has smaller bezel to head, and head to body gaps.. the parts fit closer:
I like the new TS10V3 body very much!
Im also a big fan of the USB-C 14500 ![]()
This is so useful to know, I’ll avoid the V3 then as that is simply not low enough. Shame it’s a step back in that regard.
Its definitely not perfect, but.. it still has a lot of attractive features
USB battery
Aux lights
Anduril..
Small
Lightweight
Buck driver
available in Copper
519a LED
good intro light to Anduril, good for general EDC… its just not an ideal light for sublumen nightstand use, and it is not AA compatible.. for those things look to the D3AA, KR1AA, and D2.. (they cost more)
its good to have choices ![]()
It’s great there’s the choice, absolutely. I have been looking forward to this one as someone who learned about the TS10 too late to catch the previous releases, so was hoping the latest one would just be improvements on the priors. It absolutely is in many ways, it’s just not in the ways that tick the right boxes for me.
