I just received these free review samples thanks to Xtar. Here is the product page for official pics and details. (link is unaffiliated)
I am a big fan of 14500 batteries with USB-C. I like the convenience of built in charging.. it lets me travel with a light and batteries, without need to bring a separate charger. It is also convenient for me to recharge a battery at my desk, using USB-C.
I measured the length, diameter, and weight, of both the Lumintop and Xtar 14500. They are very close to the same size and weight, and both fit and work in all my 14500 lights. The 14500 w USB are also almost identical in size as an Eneloop.
Using an Xtar VX2 Pro charger, I ran capacity tests on two of the Xtar 1300mAh 14500 w USB-C. One tested at 1201mAh capacity, the other tested at 1220mAh.
The one caveat is that I must disable Turbo on my D3AA and KR1AA, because Turbo trips the protection on the Xtar 1300mAh 14500 with USB-C. The protection is reset by slightly unscrewing and then reclosing the light. I routinely disable Turbo anyway. There is no problem at default ceiling outputs.
Using the Xtar VX2 Pro charger, I also tested the capacity of a Wurkkos 920mAh 14500 w USB-C, the result was 910mAh, and a Lumintop 920mAh 14500 w USB-C and the result was 902mAh. Both these batteries work in my D3AA and KR1AA on Turbo. They do not trip protection. But I still disable Turbo for use of Anduril lights with protected USB-C batteries of any brand.
imo the Xtar 1300mAh 14500 w USB-C is a great option to add capacity and built in charging to a 14500 light. The Xtar 1300mAh 14500 w USB-C batteries, as well as other brands, can also be charged in a stand alone charger if desired.
The net result of comparing the capacity of the Xtar 1300mAh 14500 w USB-C, to the Lumintop and Wurkkos 920mAh 14500 w USB-C, is that the Xtar 1300mAh 14500 w USB-C has 33% more capacity. I like that! ![]()
