Howdy Folks!
I've been poking around BLF for a while now, getting ideas on which parts will work for my needs, and finally ordered from Mountain Electronics (haven't arrived yet, so obviously I'm itchin' to get started
Here's what's coming:
Host: UF-1405 Zoomie (2*26650)
Driver: Qlite 6V + Zener mod, with 8*7135 added
Emitter: XHP70 N4 3B (6V) (Rated 4,022 lm @ 32W)
I studied Cree's data and test results from pommie, and came up with the following:
-The driver supplies 3.04A, plus the 7135's (at ~0.35A each), so 5.84A total,
-According to the graph linked below (posted by pommie), at 5.84A I should be at roughly 6.67V across the LED leads (my best estimate),
[quote=pommie]
!https://farm8.staticflickr.com/7567/16071892179_7d89411e10_o.jpg!
-5.84A * 6.67V = 38.95W
-At 5.84A, pommie's graph shows ~4.200 lumens. (Since I'm almost 7W over the LED's rating, that sounds reasonable I think).
-Cree states the min. luminous flux @85 deg. C = 1,701 lm (I'm interpreting this as similar to OTF lumens).
So, if 32W works out to ~1,710 flux, proportionally at my expected 38.95W I should be at about 2,081 flux. Since the lumens per Amp trend downward as amps increase, I rounded down to 2,000 luminous flux.
Now, I know this is certainly approximate, but I'm wondering if I'm pointing in the right direction with my logic. Any input is appreciated. Thanks for reading!
-Ayloxs
(I'll work on photos after everyting arrives
