First timer building an L2P based flashlight hopefully 3A
Would anyone be able to cast their eye over my planned first P60 build please? I’m after something that will fit in my jacket pocket, will throw a bit but also be general purpose/up close and is rugged. And looks good. So I’ve already got an L2P coming.
I think I want an XP-G2 on a copper star - noctigon or sinkpad. I’ll reflow this onto a custom aluminium pill I’ll turn up (I know how to solder to alloy). I’ll make it a close fit to the body, maybe even so I have to apply some gentle heat to the body to get it to fit.
I was thinking of using a KD 7135 V2 8 driver. I’m hoping with the copper board reflowed to the aluminium pill which is a light interference fit to the body I can drive the XP-G2 to 3A on high. Is this driver suitable? It will be used more on low and mid, but I’d like the option of cranking it up if I want to spot something a way off. I’m wanting to drive it with one 18650. Any other driver suggestions very welcome.
Haven’t thought about the reflector but about to look into it.
So am I on the right path here? Does everything add up and am I doing enough to get rid of the heat? Never done anything to do with flashlights before so and I’ve gathered all this from researching mostly on this amazing forum!
Thanks for any help
Depending on what kind of optic or reflector you’re planning on using, an XPG2 might be a little too throwy for closeup work. If you’re making a custom optic/pill, it might be necessary to install a longer spring on the 7135 driver if the assembly is shorter than normal and you’re using unprotected cells.
I’m a diehard fan of P60 lights, and while they’re not the best out there in terms of heat management, with a copper board and decent pill they can handle 3A without any issues.
+1
I don’t see any heat issues at all. You’re on the right path. Proceed (and post pictures) and when you hit a snag let us know and we’ll help you out.
You definitely are on the right track! I just wish I had started with a build that good! I would recommend this instead of the KD driver, it has much better modes.
Didn’t see any reference to colour temperature in your post… decide for yourself if you want a warmer (yellow/ incandescent -ish) light, or a whiter temperature. It’d be a shame for a great build like this to come up short on tint.
At 3A it’s not a big deal but a tin foil wrap isn’t a bad idea.
wedgetail, i am just wondering how would you be able to reflow the board to the aluminum pill? Kind to share me the technique? Thanks
Might be a language issue here. The emitter star won’t need reflowing to the pill but the driver does need to be grounded so if you have an aluminum pill instead of a brass one you can try sanding the edge of the pill wetted in flux and immediately tin with solder or you can just go for a mechanical attachment of the ground by soldering a thin wire to the ground ring of the driver, bending it over, and press fitting it into the pill.
Qlite driver as posted by Legolas Jr would be a good choice.
Consider spring bypass at driver and tailcap with Cu wire if you really want to see the full 3A. Don't leave it running unattended on high for long periods.
There are many P60 reflectors. Just make sure you have one matched to the emitter. Ie. XP-G model. If you can spring for an AR lens as well, you may get a slight increase in output.
In such a small reflector your throw won't match larger lights, but at 3A it should be pretty good. If the hotspot annoys you up close, you can always fit a diffuser.
Looking forward to seeing your finished product!
Well like I said general purpose. But that may well include sitting on top of a rifle where I want some throw. But also on mid/low up close in truck chassis and roofing. Would an XM-L2 be better suited?
Thanks for the pointers guys. That Qlite driver looks good, might give it a go instead. I hadn’t given tint much thought actually, and thinking about it I’d prefer a warmer incandescent style light.
Are you meaning round the pill? If so I think it’d be redundant as I’m planning on an interference fit between pill and body. Tell me if you meant somewhere else.
Well the soldering to aluminium bit isn’t too bad - just have to pre tin by running a sharp hard object (small screwdriver in this case maybe) hard through the still molten solder pool. This exposes bare metal while not allowing it oxygen (which it needs to oxidise) but having the solder right there. No fancy fluxes needed. However, doing it while at the same time reflow the LED to the pad is another matter. Will just have to work it out on the fly
Not so sure it is. I’m only repeating what I’ve read on here and CPF, but I was wanting maximum heat transfer from the LED to body. The first step after the star is getting the heat transferred to the pill and soldering is the most effective way of doing this. Is this a flawed logic? I know the other way is through the reflector but if I have the pill an interference fit with the body surely this is better? Your method of sanding the aluminium while keeping a layer of flux over it at all times sounds a good one though.
Liking the wire bypass idea if I’m not getting the current. What do you mean by AR lens? Is this an optically coated one for better light transmission? Won’t have it on high for long periods and I’ll mostly be holding it so will know how hot it gets.
AR = Anti-Reflective. Yes, optically coated. Don't expect much improvement over a standard lens but up to about 6% may be possible.
There are some good tips around here re spring bypass. Look in the X6 GB thread for a Youtube clip by Dale (DBCstm) if you want to see it done live. At 3A the stock springs will probaly add an appreciable resistance so bypassing would give a bit of a boost.
This may help give you some ideas if you go the P60 route.
Having the led on a copper mcpcb is much more critical than reflowing the star to the pill and at 3A not a big issue anyway but if you have the bound to’s then use a drop in with a brass pill instead to avoid the difficult soldering aspects of aluminum. P60’s aren’t throwers but easily mod able general purpose lights. An XP-G2 will throw better than an XM-L2 though and still be ok overdriven if on a copper DTP star. More throw can be achieved with an aspheric lens.
So are there any gains to be had from soldering to the pill? Reason why I want aluminium is because I have suitable sized blanks for tuning so can make it an interference fit with the body. I can solder to aluminium so that’s not so much an issue, just handling the molten solder round the LED
At 3A it would be impossible to see the difference and very hard to measure but modding is all about floating your own boat. Heat from the led starts in a very confined space (the die) and spreads out slightly to the solder joint under the die. Allowing it to go from that small area to a copper star immensely increases the volume of metal to dump the heat into and multiplies the surface area for the next thermal transfer. At that point decent lapping and a thin layer of thermal adhesive is all that’s needed. Beyond the pill, having an interference fit is better than P60’s are to begin with so you are already ahead there. You won’t see any thermal advantage from soldering to the pill unless you ramp the current way up and you run a further risk to the led with the added heat necessary to solder. It’s still up to you though. Do what you want to do
Just having problems finding that thread - what sub forum is it in?
Well I’m certainly not looking for more work for myself than I need, so if it won’t help I’m happy. Not sure I’m fully following here though - you say the interference fit between pill and body is good (yay!), but for that to make a difference surely the pill is taking at least some of the heat. Will the solder not be providing a path of less resistance to heat than what a lapped and thermal adhesive layer can provide? Or are you saying the difference is negligible?
This is true. I have an L2m with a Sportac Triple Nichia. I don’t know exactly what the current draw is, but it gets REALLY warm REALLY fast. I’m not sure if it’s dangerously warm for the drop-in (it has a PERFECT, tight-fitting aluminum foil wrap). But I generally don’t like to run it continuously for too long in warm conditions (it’s more for light painting and night hikes). In fact, when I runtime test it (since it’s running two unprotected cells in series), I sometimes ice it down just to be on the safe side.
By the way, can you get a better finned head for an L2 for better cooling?
