For reference the VG15S is 1000 lumens and 200 meters of throw. It is 122mm long and 24mm in diameter.
If you want something more compact you will almost certainly need something with a side e-switch. And if 24mm isn’t pocketable enough then you can’t get a more throwy light by using a bigger reflector.
Punching those requirements into my search engine find the $50 Skilhunt DS21 HI. It is 1cm shorter and throws 19 meters further.
Basically you are already doing about as good as you can. An XP-L HI e-switch light will be a marginal improvement.
