FiTorch is a newer brand to me and this is the first light I have looked at from them. It’s designed for EDC use, has onboard charging via micro USB, magnetic tail cap, and a deep carry pocket clip.Thanks to Banggood for sending this to me to take a look at.
Full Image Gallery https://imgur.com/a/vswz9
YouTube Version of this Review: https://youtu.be/ayPbeShrNas (Thanks for helping me reach 10k Subs)
Packaging
Packaging is a black orange retail style box complete with a hanger. On the rear you get lots of details such as lumens, runtime, battery, and other ratings. Inside you get the light itself in a plastic try along with the accessories including the deep carry clip, lanyard, branded belt holster, and one oring. The holster is made of black nylon, is branded with a sewn in flag. It’s belt loop is fixed, and it doesn’t have an oring. It’s sides are elastic so it fits the light well. You will need to be careful with button placement so you don’t accidently turn it on.
Construction
This light is made from aluminum that’s hard anodized black. Machine is above average quality and inline with the price of the light. The tail cap has circular groves running around it as knurling with 4 pockets milled in to provide extra grip This light unscrews in the middle which is a little different from many. There isn’t any knurling on the body tube but it has enough cuts to provide grip. Threads were nicely greased and fairly fine. For a light of this size it has quite a few threads.
The front end of the light a hexagonal area milled out that contains the button and USB charging port opposite the button. This are is milled out to act as a heat sync The button itself is flat and metal, it’s a floating style button. I do recommend using lockout with this light if your going to carry it in a front pocket. Around it is a small clear bezel with multicolor LED’s under that acts status indicator for power level and onboard battery charging. Further forward is a smoothly milled area where the emitter and lens are.
The bezel is not removable as a front piece itself, itls a larger component and it’s lightly crenulated. The lens itself is anti reflective coated glass. The reflector smooth and fairly deep, and the emitter is nicely centered.
This light is rated for a 16340 battery but there is quite a bit of extra room in the tube when your using a 16340 so I decided to try a flat top 18350 that I had on hand. I had to add a magnet in the center of my flattop to make the light work again because of the physical reverse polarity protection built in but it will work and there is still a bit of extra space left in the tube. With the 16340 battery installed I didn’t have rattle because of the pretty strong spring in the tail.
The light has a strong magnet that very easily holds the light’s weight on a metal surface both horizontally and vertically. No weak magnets here, it’s the way it should be. It’s strong enough that it holds the battery in place too even though there is a spring in between.
93.3mm in length, 27.7mm at it’s thickest (Button) and 23.7mm at it’s thinnest.
Weight with my KeepPower 16340 is 91.3g
Water Rating is IPX8
For a 16340 EDC light it’s a little bigger than I expected. For a front pocket EDC the more lights I test the more I have determined diameter is one of the most important factors and the ER16’s is just a little bigger then I would like. If you have an Emisar D4, it’s pretty similar to that in diameter and length. Lengthwise the ER16 pretty decent. This being said it carried nicely in a couple pairs of jeans. I really liked the clip on the ER16. It’s sturdy and deep carry to where there is almost none of the light showing above your pocket, exactly like I like.
LED + Runtimes + Temps
The ER16 uses a Cree XP-L2 LED in cool white, defined hot center. Output on turbo is 1000 lumens. Medium is 340 lumens, medium is 100 lumens and low is 3 Lumens. I would like to see high be a bit higher and low be a bit lower under ideal circumstances. The beam has a definite hot spot with a decent amount of spill. The light throws better than I expected too. Easily out too 100 yard which is pretty good for this size of light.
Runtime
For my runtimes I used a Keeppower 800mah 16340 battery and an Aspire 1100mah 18350 for comparison. Turbo lasts for about 5 minutes on the 16340 decreasing as voltage drops. It’s more stable on the 18350. The light does step down as you can see from the graph. It’s making usable light out to about 90 minutes. With a 18350 medium lasts a bit longer but the biggest difference with is how much longer low runs for. It makes usesable light out to about 150 minutes before entering low mode at 3 lumens. If you can use an 18350 instead of a 16340 do it, because there is almost no penalty in doing so.
UI
The UI of this light goes as follows Turbo > High > Mid > Low > Turbo. It’s unfortunate it starts in turbo. I think this limits it’s practical EDC use because many times you don’t want to start off at 1000 lumens. There is memory but it’s pretty short in how long it remembers. You can double click to get to strobe and single click to exit that mode.
Lockout is accomplished when the light is off pressing and holding the switch and the indicator will briefly flash red letting you know its locked. Doing the same thing will unlock it and low mode will come on in the main beam.
Voltage check is well done on this light. From off triple click the button 3 times in a row. First you get green flashes showing the first number of the voltage so 3 would be 3 volts then you get red flashes showing the next digit. So 3 green 1 red would be 3.1V.
Charge Graph
This light has onboard USB charging via a micro USB port on the body. As I mentioned earlier the unfortunate thing is that this microUSB port is buried deep requiring a longer then average cable to recharge. For me this kind of defeats the purpose of MicroUSB recharging if I can’t use a standard cable. The light can charge at 1A but it didn’t hold there for to terribly long only about the first 30 minutes before it started slowing as the battery (800mah Keeppower 16340) reached capacity. Terminating voltage was 4.1V. Total charge time was 1 hour and 9 minutes.
Pro
*Quick charging for a 16340
*Fits 18350’s by surprise, nice for extra capacity
*Sturdy deep carry clip and a strong magnet
*Throws well for an EDC light
Con
*Extra deep micro USB connector means most standard cables won’t work for recharging.
*Wish the UI would start on low instead of Turbo.
Conclusion
The FiTorch ER16 has some pretty stiff competition in this size and use case. For me the ArmyTek Prime C1 probably wins out due to it’s slightly thinner profile and button that is less prone to accidental activation. However the ER16 throws further and has a smoother beam profile over the Prime C1 Pro. My recommendation for FiTorch is that they make the UI start on low, and not recess the microUSB connector quite so far so that you could use a standard cable to charge it. If you don’t mind these things the ER16 is a nice light that charges pretty quick and has a strong magnet. It will work well in an EDC application for you.
You can pickup the ER16 on Baggood if you have any questions please let me know below.
