I think you are right about the picture. I just looked at one image and didn’t get the full picture.
100K ohm resistor is quite a bit higher than I’d use in my designs. Check it with an ohm meter without power. Even though its in circuit, it should read near or lower than what the actual value is. If the problem is this resistor (and its function is to pull the gate to ground when no control signal is present), then by shorting the resistor via a pair of tweezers will put ground to the gate and the mosfet should be off. Tells us what happens after you try that.
My assumptions right now are that its an N-channel mosfet where the Source pin of the mosfet is grounded. If one end of this resistor is not tied to gnd, then that changes things.
