Hi, just took the pill out of my 501b to change the driver to single mode and the dome fell off my XR-E.
Put the dome back on and pressed on it firmly and then checked the beam on it and works perfectly still, is there any way to fix it on permanently and how is it normal fixed to the Led as fell off easily.thanks terry
I don’t know how it’s normally fixed on.
Norland optical glue might work. But it’s expensive. And you’d need a UV light to cure it.
It would be far cheaper to just buy a replacement LED.
Led seal.
i rip domes off xr-e\c on purpose, if you have no problem what beam looks like with dome off, don’t bother glueing it back. led wont even notice it.
I’ve only de-ringed one XR, is it fairly common for the ring to pop off the ceramic substrate without disturbing the gel?
Also, some P60 modules must be designed for XR. I don’t have many modules, but the one I have with the best beam is an XR-E Q3 5B with SMO reflector. You have to see it to believe it, perfect, tight, even spot, rings barely visible, it is my dragon.
