flashing a FC13S
Can a FC13S be flashed to a FC13 ?
Does the bottom of the driver look the same? if so, you have a good chance, assuming thy didn’t change anything else. On their other flashlightts, the simple version has a different driver IIRC.
The FC13S are on sale for $20. But I like to flash It.
Ah, then I can only guess. In this Reddit thread some say it might be possible, but no conclusion yet. Maybe someone here knows, or you can try yourself :wink:
No, the FC13S cannot be flashed with Anduril because it uses an unsupported microcontroller AFAIK.
Thanks
I’ll ask it here also. Is the fc13s regulated ? I can’t find mention of that in any reviews .
I don’t believe the FC13S is regulated, but the TD05 is. They’re similar in form factor, though more closely related to the FC12, as it also employs the SFT40. Still a good light either way though.
I grabbed aTD05 on a whim - now it’s my go-to recommendation for newb, tactical-ish, simple all around use…
The 5000K SFT40 is quite nice!
You can always test by just executing
avrdude -c serialupdi -p t1616 -P <COM Port>
If you see a microcontroller in the message that means it’s AVR and could be programmed
