Cheule
(Cheule)
June 25, 2021, 3:53pm
1
This is a KR1vn firmware question.
When I firmware flashed my KR1vn to Anduril 2, I just instinctively used the precompiled K1 SBT hex that is available on ToyKeeper’s hex repository (Index of /torches/fsm/anduril2 ). It works well.
However, later Vihn told me he uses the KR4 FET bin from ToyKeepers site.
Those of you that know the differences, is there any? Does is matter in the case of this model?
Cheule
(Cheule)
June 28, 2021, 5:29am
2
I thought I’d post a follow up for posterity. ToyKeeper got back to me via reddit and said:
The KR4 and K1-SBT90 configs are pretty similar… but only by coincidence. The KR1 is designed to use the KR4 builds.
Switching to the K1-SBT90 build might make factory reset stop working, since it expects a “loosen tailcap, hold button, tighten tailcap” style of factory reset and that might not work on the KR1’s tail e-switch. However, the K1-SBT90 build uses a higher temperature limit by default and less aggressive thermal throttling, so it’ll likely run hotter when used at full power.
They also have some differences for how they treat aux LEDs and button LEDs, but the KR1 doesn’t have those so it doesn’t really matter.
I don’t have a KR1, but if I ever get one I’ll probably make a separate build specifically for it. The ramp shape is probably not ideal, since both KR4 and K1-SBT90 are calibrated for lights with a different ratio between the power channels. This pic shows what I’m talking about… The labels are wrong, but otherwise, both KR4 and K1-SBT90 look like the graph on the left… and when their firmware is used on a KR1 it probably looks more like the graph on the right. So it could probably use some ramp shape adjustments.
