Flashlight + Beer
Hi all. Greetings from Spain.
I am not new in the forum, I have been reading you all since 2013, but it is the first time I will post. Sorry for this, I am not a great writter.
I want to ask you all, as I am sure you will be able to help me. I assume most of you like beer, and of course flashlights!
I would like to buy a small EDC flashlight, that can be used as a keychain light, and at the same time, it integrates a bottle opener.
Something like this: https://www.fasttech.com/p/1532502
(I have this one, but light output is not good, and it doesn´t opens beers good at all, you need two tries mínimum. Also, at it is made of Aluminium, after few uses it becomes scratched)
I have been checking for it for a long time, but the ones I find don´t fit my wishes.
I would like to have 100 lumens or more, in a compact 1xAAA size, as much lightweight as possible, with some modes (moonlight would be nice to have) and a good termination and durability (maybe stainless steel?)
Any recommendations will be welcome! Sorry for my english.
Thanks in advance.
Welcome to BLF!
Your English is great
Nice question can’t help you with that
I hope you have fun here, JBAlvarez!
EDIT: I just did a quick search for you.
I can't find a decent flashlight that has a bottle opener.
Good luck with the search!
the combo can be found, but I think none of them are really bright For smokers who do not mind not having it on the keychain
Not a flashlight , but the SanRenMu H03 has a really good bottle opener on it …
That’s what I thought of too. I would have bought this knife myself but I didn’t like the fact that it has a bottle opener.
For you it could be ideal. It’s always good to have a small knife in your EDC kit. You could then get something like Olight i3s. Aluminium is good for heat dissipation and not good for bottle openers, steel vice versa.
I think you will find that good lightweight flashlights and flashlights with bottle openers are two separate categories.
I have looked for something like this for a longer time and never found one. :frowning:
I guess it’s because a lot is designed for US market and they don’t need bottle openers…here in Europe we don’t have the twist caps everyone needs an opener…
Would be easy to build a reasonable AAA light with a bottle opener for under 10$, Or a nice stainless steel one for about 30$. But there is simply no demand so it will never be done.
Also there is a lot of difference in the anodized alu openers(without led) you can get, I had some which lost the ano on first bottle and were eroded to dead after 24 bottles…others survived years on my keys and opened hundreds of bottles.
A lot openers do work but not very good, for example on my leatherman micro the opener works bad and I have a “key tool”, which is basicly a sleeve for a key with some “useful” tools, doesn’t work very well too.
I always thought about cutting a head of a key for the bottle opener use or letting a simple thin Titan sheet cut to form but never found time to research it entirely…that would mean to order all the tools with opener included to do a comparison which one works best.
JB, you write well but apparently you’re still new at this beer thing :-). Just kidding…
It’s too easy to open a bottle, no tools ever needed. You can use a plastic lighter, a disposable wooden chop stick, a key,
or if your buddy is passed out, use his teeth. Haha.
Use 2 bottles against each other to open because you really shouldn’t be drinking only 1 beer anyway.
Welcome to the forum!
I like the idea of a small EDC light with a bottle opener, as long as the opener doesn’t make the light too large or otherwise inconvenient.
I wonder if something like this could be integrated into a light? Maybe the light could be extended into this shape, or maybe this tube could somehow fit around the light?
Or if someone were so inclined, they could probably build a light right into a piece of pipe like this (preferably in copper, if that’d be strong enough for an opener…) :cool:
EDIT: Thinking about this a little more, it might actually be feasible.
polished SS tubing ($8.06/foot plus shipping) should fit pretty tightly around AAA cells. One foot of tubing should be enough for 4 lights (1xAAA), so you could sell a few to recoup your costs.
Then you could either use guts from another AAA light, or get a 10mm driver & emitter. (Richard sells drivers for li-ion cells). Not sure how easy it’d be to find a 10mm lens or reflector, but lights with these parts are cheap enough.
Who’s on this? :wink:
Just found this on GB
http://www.gearbest.com/bike-tools/pp_322049.html
looks nice and useful
Welcome to BLF! What took you so long?
Looks like (a clone of) CRKT Get-a-Way Driver Torx ( http://www.crkt.com/Get-a-Way-Driver-Torx-Set ) for a much lower price.
While it could be a pretty compact screwdriver, the flashlight part is just a basic button cell key chain light. If you don’t need a screwdriver, Nitecore Tube (45lm, 9.6g) and a separate bottle opener would probably weight less and provide more light.
This seems to be the smallest bottleopener I could find right now. Sold as titanium…it’s a cheaper copy of the pico opener which was on kickstarter.
http://de.aliexpress.com/item/Titanium-Micro-Bottle-Opener-EDC-Mini-Lightweight-tool-multi-functionoutdoor-tool-keychain-Free-Shipping/32548570019.html?spm=2114.010208.3.102.6dZNSk&ws_ab_test=searchweb201556_1,searchweb201602_3_301_10034_507_10020_10001_10002_10017_10010_10005_10011_10006_10021_10003_10004_10022_10009_401_10008_10018_10019,searchweb201603_2&btsid=c0e65420-d57f-4160-b9b1-b847fb45b501
Smaller EDIT, wow that thing is small that is probably the smallest opener I’ve ever seen! / and but cheaper
With a keychainring it can be put with your keys
http://s.aliexpress.com/yqmai2qI
edit i missed the shipping on that
So here it is free shipping for a whopping $0.34
http://www.aliexpress.com/item/1pc-Stainless-Steel-Finger-Ring-Bottle-Opener-for-Beer-Bar-Tool-Hot-Search/32433561626.html
And OOH this is nice!
http://www.aliexpress.com/item/Key-Portable-Bottle-Opener-Beer-bottle-Opener-Hangings-Keychain/32492376346.html
Will not stand out on your keyring.
The old fashion way. Use one of these as the bottle opener, and your headlights as the flashlight… problem solved
Hi all.
Thanks for your welcome words!
It seems my search will need to continue… But thanks for all the ideas.
Andyman, I like yours!
This one pleases me, thinking about “multifunction”:
especially since it allows you to use the LED to light your way for cutting and bottle identifying/opening (and writing, possibly!). I think one of these would be perfect for the BOB and the boat! I don’t have one to report about, but it is now on my list, thanks to you.
Thanks for a stimulating question!
PS: WELCOME to BLF! Keep asking!
