Look what I found on AliExpress
http://s.aliexpress.com/n6viEvQv
I found this flashlight on AliExpress that is 3 XHP-70, I’ve talked with them and this is what they sent me about specifications. —-Emitter:7070
v —Aluminum Alloy body with HAIII Anodize black surface Finish
v —Battery: 4x High Drain >10A button top 18650
v —Switch: Side electrical switch with big Transparent rubber boot
v —Aluminium OP Reflector
v Ultra Clear Double-sided AR coated Glass lens (99% Light transmision )
v —Double O rings; IPX8 Waterproof
v —With standard Tripod hole
v —Max Brightness:13000 LumensNW ;
v —Max Runtime: 58 days
v —Brightness Level: (Digital current regulation)
v Low Low: 10 Lumens (28 days )
v Low: 150 Lumens (35 hrs to 10% power)
v Middle: 1000 Lumens ; (480 minutes to 10% power)
v High: 2700 Lumens (250 minutes to 10% power)
v Hidden moonlight: 0.6 Lumens ; 58 days
v Turbo—13000lumens —–2.5 minutes (thermal control) step down to
v 6000 Lumens—–2 minutes (thermal control) step down again to 2400
v Lumens (300 minutes to 10% power)
v Overclocked descent55 degrees 2.4 A-2.6A
v 6000 Lumens55 degrees 1.4A-1.6A
v — Timed Temperature stepdown and thermal regulation
v Size: 135mm length x65mm Head x53mm body
v Weight:460 Gram
Ø User Interface:Single Click-on ; Single Click-off
Ø Hidden Moonlight (press and hold switch in off status; easy to access)
Ø Low Low-Low-Mid -High-turbo (Long press to change
Ø modes ; with last mode memory)
Ø Quick access to Turbo (Double click after you turn
Ø on the light) ; Turbo can be memorized.
Ø Click+hold+flash signal to lockout the light;
Ø loose the flashlight body to unlock.
Ø Switch LED indicator:
Ø 100~50 power: Blue LED on
Ø 50~9 power: Blue LED flash twice every 2 seconds
Ø Blow 9% power: The flashlight will flash fast and step-down to moonlight.
Ø The indicator LED will be off on Moonlight mode to extend the run time.
Ø Internal parts:
Ø 40mm Haike Copper DTP Emitter board
Ø 20 gauge thick copper+silver wires
Ø 5mm thick internal integrated emitter shelf
Ø double silver-plating copper-alloy springs
Ø Caution:
Ø The Turbo mode gets hot very quick!!!
