Flashlight reccomdation
I got some money over the holidays and want to upgrade my edc flashlight. It’s a convoy S2 and I want something similar but higher end. It has to be easy enough to carry in my pocket all day. Looking to spend 50-100$
Do you want more lumens, longer runtime, USB charging, Anduril, side switch, 21700, some or all of the above?
Or something else not mentioned?
I like the Acebeam E70-AL, though it might be too large for some people.
It uses a 21700 cell, and it's reasonably compact.
I’d recommend anything from Hank
https://intl-outdoor.com/
D4v2 for example
If you want something small and efficient with low parasitic drain, try one of the SC64 series from Zebralight. It will melt into your pocket.
If you want something more exciting and a little less practical, try a D4V2.
Nitecore E4K, I love the beam, Flood/wall light cool white but no excess for Nitecore :stuck_out_tongue:
You can put the 4000 lumens at your feet with no blind :slight_smile:
Proprietary cell’s
Check UI before, little tricky , but I think they release new version with better UI
Pics for compare: D4SV2—E4K—Samsung 40T—E-70— BLF A6
you need to say how you want it to be different or better than the s2+
you said smaller
FW3A is smaller, and only about $45
wle
Thank you for the pics, that helps me a lot :slight_smile:
More lumens, I want one that can use normal flat top cells which seems to exclude Fenix.
If you want beauty and bigger 21700 battery I believe Acebeam E70 as Raccoon City suggested
If you want smaller 18650 multi emitter I’d suggest Noctigon KR4
But don’t discard Convoy, my S2+(Nichia 219b) in clear finish is beautiful, and the purple my wife “stole” and she don’t even like flashlights.
Yeah my wife uses the Convoy S2 beacause it’’s simpe to use, it’s also impossible to destroy. I’ve dropped it on concrete multiple times and still works
I bought a second purple S2+ to replace the one my wife stole and my daughter stole that one.
My wife doesn’t like flashlights either, she uses her cellphone but her eyes sure lit up when she saw that purple S2+.
