Looks like a fun mod, well done ![]()
Whoah…awesome
hehe ![]()
I can hear the auxiliary nuclear kicking in J)
Id love a light built with those emitters good job,!
Nice effort OF. Its good to see you have a win. Do you know the reason the modes aren't working?
You have mixed em well!
I am also interesting why the modes arent working.
Nice wall of light :-)
I have had that one mode thing several times, sometimes it means that something shorts and that the light runs direct drive bypassing the FET. A more complicated reason could be that the MCU does not receive the right voltage (higher than 5.5V)? I guess with your wiring the 10.8A at the tail is directly divided in two, so 5.4A each string (and so to each led).
Nice effort OF. Its good to see you have a win. Do you know the reason the modes aren’t working?
I’m thinking I might have cooked the MCU when I did a Zener mod on it several weeks ago. Would that cause me to lose modes and just DD?
At the time, I didn’t realize Zener diodes should only be installed one way. Once I found this out I reinstalled it in the correct position, but I guess it was too late.
Before I put it in this light, I tested it, just to make sure it was working, but didn’t think to try running through the modes.
Note to self: double check everything.
I have a BLF17DD all checked and set to go. I’m having some vision problems, so I’m waiting for a good eye day to swap in the new driver.
I took this wall shot just to show the hot spot on this light. I know it's muted, but my ipad was blinded by all the light. It finally focused the light down to a level that it could accept. Even though all the surrounding light is muted, the hot spot is pretty true to life.
I was worried that the two MT-G2s would give an odd beam profile, but that's not the case. All four emitters are nicely focused.
Well, I replaced the driver and now I have five modes. High is nice, but it can only be run for about two minutes.
My eyes are failing and it took me two days to replace the R200 resistor. When I finally got it in place, the capacitor had fallen off. I took one off a NANJG driver and replaced it and got the Zener diode on. Everything was making contact where it was supposed to, but it looked like a Salvador Dali painting of stonehenge. I goobered a bunch of AS Epoxy over everything to make sure it stays in place.
As soon as I have my eye surgery I'm going to get my eyes retested. I've had this prescription for three weeks and even went back to have them make the lenses over again, but I'm still just seeing blurry doubles close up. I hope I don't have to give up modding.
Another milestone. I just finished my first roll of solder since I learned to mod.
Edit: The way I mount my driver in those brass retaining rings, I'm always worried about losing ground with the edge of the driver, so I used RaceR86s idea of soldering a ground wire directly to the FET. I think that's the way to go.
Wow.
Very Interesting…
awesome work! those on-off pictures really do tell a tremendous part of the story. Thanks for sharing!
Fantastic mod!
That'll find all the loose change under the couch.
Congratulations on the first solder roll, givaway? ;-)
I really hope the eyes will be a bit better soon, it is no fun when the eyesight gets worse!
I can still see enough for modding but I recently started using lots of light and a loupe for a few things that were easy before. I'm still in denial!
Sweet mod!
How do you like it compared to your other powerful and large lights?
It’s bright, and it floods, but the current drops pretty rapidly. It gets mighty hot mighty fast on high.
I haven’t had them out side by side yet (maybe tonight) but I kind of like my Tr-J12 Hybrid mod. , mostly because of its more compact two cell form factor.
If it stops raining tonight, I’ll see which out floods (probably this one), and which out throws. The TR-J12 has four XM-L2, but smaller reflectors.
Thanks. Nice to see the lights side by side like that. Puts things into perspective.
Looking forward to hear more about how they compare.
Bit of a necropost, but hope this helps anyway. If your light takes 10.8A at the tailcap, then assuming the two strings have roughly identical total Vf, each string will take 5.4A. As the MT-G2 and the XM-L2 in each string are in series, they will each have 5.4A going through them. So according to Match’s graphs, your XM-L2s and MT-G2s are making 1650 lumens and 2900 lumens each for a total of 9100 lumens!!!
BTW, anyone know what host this is? Googling didn’t help.
