Floody Lights Using 1 x AA Or 1 x AAA Battery?
Looking at lights with floody output.
Something like the Sunwayman T16R (which is a very floody light I believe), but using AA or AAA battery instead of the CR123.
Requirements -
Must use either a single AA or a single AAA battery.
NO zoomy type lights.
Must have multiple output levels.
Must have mode memory.
Must be clicky switch ONLY (rear or side mounted); NO twistys please.
Must be principally a small(ish) handheld light with NO right angled light output. NO headlamp lights please.
Suggestions please?
Thanks.
The Maratac TPF would have been perfect right up until the part about twisties.
Looking at <a href=“Parametrek FlashlightsAA/AAA lights sorted by flood the Zebralight H502 is the champ. As a mule it doesn’t get much floodier. A less expensive option is the Manker E03H which is very floody when the diffuser is deployed. The Fenix HL10 is AAA and also has a diffuser.
What about Olight S1A ? It has TIR optics with wide, floody beam.
I am unaware of any AAA lights w Mule or Aspheric optics.
The McGizmo Mule and McGizmo Sundrop (aspheric lens) offer an AA body option, and both are very floody.
The Sunwayman you mention uses an Aspheric lens. It is MUCH MUCH MUCH floodyer than the TIR on an Olight. I know of 2 other lights with the same aspheric lens, the Utorch S1 Mini, and the Klarus Mi1c (aluminum version only).
here is the Olight S1 Mini w TIR lens, it is a bit of a fuzzy beam, no distinct hotspot. Im standing 12 feet from the wall.
and the Utorch S1 Mini w aspheric lens, the beam is much wider
and the Worm, which has the same beam as the Maratac AAA and Tool AAA, with the most defined hotspot
[/quote]
Im Loving my aspheric experience for close range indoors.
Thanks for the suggestions so far!
I have added to my requirements that the light should be basically a handheld type and light output should NOT be right angled (like in a headlight).
I'm currently working through the specs of some lights and will post comparison results soon.
consider how floody is good enough,
ranked from most floody to least floody:
Mule, McGizmo w AA body
Aspheric, 3 brands, all CR123/16340, except the expensive McGizmo w AA body
TIR, Olight S1A… possibly the closest match to your criteria, though not as floody as an aspheric, not even close ime
Reflector, everybody else… reflectors are not floody
fwiw, illumn.com has a promo code blacknovember that will get you 30% off one of the AA powered Copper S1A Baton:
https://www.illumn.com/olight-s1a-cu-raw-copper-baton-xm-l2-600-lumens.html
they have other models too, including a Ti S Mini (CR123 that you dont want, yet)
Im not affiliated, just a happy consumer
my floody light is a Utorch S1 Mini, that came with a really cool USB rechargeable battery, that you dont want, yet :slight_smile:
I suggest the ZebraLight SC53Fc AA Floody Neutral White High CRI Flashlight if you can afford it. It doesn’t have mode memory, but the ZebraLight firmware is easy to learn and very flexible.
I have the AA (or 14500 li-ion) SC52w L2 which was my EDC for a long time. Very small, great efficiency, side switch, pocket clip, nice tint, and rock solid. ZebraLight has had issues with green tint, but both of mine are awesome.
I am in the same situation as u. Wanted something AAA / small and compact, took my Lumintop Copper Tool AAA and mod it to be a full on flood light.
Before
After
Mods
Using aluminium insert to replace the reflector
nice mule! thats a first for AAA that Ive seen
congrats
Thanks :slight_smile:
Was racking my brain on the mod…
Took the idea from mcgizmo mule and worked something out.
Turns out to be perfect.
here is another AAA Mule, was produced by Oveready.com a few years back, I dont know if they are still available, but it is off topic for the OP, since its not a clicky… I cant resist posting a pic anyway
and some examples of mule and aspheric beams, with a conventional reflector beam for reference
on the left is the type of beam the OP first asked about, as in the Sunwayman, Utorch, and Klarus lights mentioned
on the right is a full mule, no optics
aspheric outdooors
and a reflector beam outdoors
Utorch UT01
Manker E02 and Manker E03 . These are headlamps, but can be used as regular flashlights!
just curious, what is meant by a “mule” flashlight? reflector-based?
A mule doesn’t have any optics
Olight S1A. The beam is about 27°, which is slightly floody but not quite floody enough. The Niteye SE-A01, for example, has a beam angle of about 37° which is nearer to what I'm after.
For the other replies, the light MUST have mode memory, MUST use AA or AAA size batteries ONLY, must NOT have a right angled output (usually seen in headlights), and should NOT be a "modded" light.
The Utorch UT01 is a clone of the Manker E11 I believe. The beam angle of these lights are about 34° which is fairly good, but I would prefer a wider beam angle if possible.
Peak Eiger
AFAIK Oveready was the first to sell the mule heads but you can order them directly from Peak.
That being said, no mode memory or clicky (momentary switch is optional) so likely not quite what the OP is looking for.
So I tell you my story. I bought Armytek Prime A1 PRO some time ago. Nice flashlight, maybe too big, but with great UI and impresive output. It has TIR optics, but I hate it - it produced one of the ugliest beam Ive ever seeen…
What to do? Thanks a member of this forum I discovered this store https://www.aliexpress.com/store/219000
…and bought this lens https://www.aliexpress.com/store/product/Free-shipping-plastic-cree-lens-Diameter-20mm-Bead-surface-15-degrees-High-power-LED-lens-XP/219000_772880537.html?spm=2114.12010612.8148356.6.6ba72134o6KE50
…and replaced the old one…
Now with 38° lens inside, my Prime A1 produces beautiful, wide, floody beam…
A piece of dc fix gives more flood than a mule and gets rid of the sharp edge of light like an aspheric lens. I thought the ring of light was cool when I was a noob but now I like an all flood beam with no transition from light to dark .
easiest way to check out a mule is just take the lens off your zoomie light .
I agree, the DC fix does a great job of helping to make a light a bit more floody and cleaning up the tint shifts and rings in the process. I prefer DC fixin vs aspheric or mule. Not to mention if you don’t like what it does you just peel it off and forget about it. I put DC fix on a Lumintop SD26, it made it an almost perfect long run time floody light. I wasn’t worried about losing throw on that light because I have other throwers in that same output category. I haven’t used it on a AA or AAA light yet. I have one of those Amutorch SS AA’s that I am not fond of the beam of that I may try it on though.
