2100
(2100)
48
Might be true, it’s quite interesting actually. Thanks for pointing that out and i shall go google and see if there are any scientific tests done on this regarding the end-user end with regards to reflected light/glare. I’m not an expert on this.
Not sure if i was reading the professor’s mini write-up correctly, the reflected glare/diffusion due to Rayleigh scattering has been wrongly used? (or is my science / comprehension incorrect). Is this back-scattering (back to the user) or is it front scattering? Since he hinted as there is no rayleigh scattering effect, does this mean that it doesn’t matter at the end-user end as well?
In any case, 5000K vs 6500K, i think effects are going to be relatively benign. If it’s 2700K vs 6500K, then yeah the CCT difference is really there.
But BLF Q8 vs Sofirn Q8 is 50k vs 100k cd, that’s pretty big (though of course you’d need 4X the cd to double distance). In any case, both lights more than satisfy OP’s 100 yard requirement.
