Hello I am after a few FLUROSILICONE O rings for a solarforce L2D build.
the AR lens is 28mm if that helps.
any idea of the size(s) I would need and where to get from ?.
I have emailed sinner too.
Anyone else?.
thanks.
Hi cri! ![]()
If you are after petrolium resistant o-rings, you could use nitrile as it is easier to find in many standard sizes. Is there another reason you are after fluro-rings?
Thanks no real reason just for the look!.
Thanks!.
bump anyone have an idea ?.
I have also contacted solarforce.
I need all sizes from the head to tail.
Thanks.
You could just ditch the o-rings and use Teflon tape on the threads. Can’t beat it for chemical resistance, and I’d be willing to bet it seals just as well. Cheaper too
Just a thought
Fwd;
We just get the O-ring from our supplier.
For the head, 30mm(Dia.) x 3mm(Thickness)
For the tail, 20mm(Dia.) x 1.5mm(Thickness).
Anywhere to get these in BLUE FLUROSILICONE sent to me please ?.
The O ring store tells me they don’t have those sizes!. :-/
What’s the best next way?.
Any other place ?, or can someone get them and send to me !?.
I’m In London now.
Thanks
