Update for the sake of it.
After some delays here and there, its finally taking shape. The sunflower heatsinks received were in fact ≈∅53 × 22mm (with one of 'em ≈0.65mm :facepalm: short in height). Hand machined the base heatsink the best I could (without drill bank), and this is how it looks after all properly aligned and glued with Tian Mu grey thermal goo:
The central hole is for the base's shaft. The holes on the underside are meant for the blower fans' sucked out air to get through, right now blocked with grey goo remnants but that is to be cleaned. The base heatsink open sides will be enclosed.
