Fluxient o ring replacement bike mount
At last, a really good replacement for O ring mounts supplied on so many bike lights. Doesn’t end up pointing at the ground like O ring mounts.
Shown here on the 3000 lumen Fluxient 3x XM-L U2 bike light:
It comes in two parts, the lower part attaching to the bars (25.6mm - 31-8mm) with an allen bolt, the part attached to the light having a quick release.
It has a limited swivel action to allow the beam tio be directed away from oncoming traffic:
torchy, this looks like a great alternative. Any idea on sources for this light or the OEM site? I can only find sellers in the UK and New Zealand.
They hadn’t thought of selling them separately until I told them there would be a big demand. They are looking for outlets outwith UK and Australia.
Torchythebatteryboy
I have the Fluxient 3xT6 with the metal mount, although it looks tough it has a tenancy to turn left/right as you ride because you can’t get the thumb screw tight enough by hand. as seen on your site.
This newer (I’m assuming) mount looks weaker but doesn’t have the right/left. What are your thoughts can this plastic mount handle rough terrain?
Found one that looks similar in the U.S.: http://www.action-led-lights.com/collections/accessories/products/bar-mount-clamp-on
The company is located about 45 minutes from my house.
The trouble with this mount is the small thumb screw doesn’t grip the stem on the lamp head, so it doesn’t stop it from turning. They tried replacing it with an O ring, which was ok on the road, but ended up with the lamp pointing straight down on rough terrain. The new mount is solid on rough ground.
They only seems to have a few customers just now. I think they would welcome a seller in USA.
Welcome to the show, JohnMcKenzie!
