Focus with pvc pipe
Hi fellow flashlite user. I am new here and I have a question.
I own a t12 nitecore flashlite, nice flashlite. It’s a good flashlite witch a use during hikes is forests. I like the degrees in this flashlite but I want to make the beam a bit smaller. Is this possible with a piece of pvc that I can use on the head of the flashlite? Gr jack
No, the size of spot/spill is controlled by the shape / size of the reflector, it’s not like a projector where you could simply reduce the apparent size with an apature (what your technically asking if you can do with the PVC).
In order to change the beam pattern on that light you can change to a different LED with a different size LES (light emitting surface) or you can just do what us guys here would do and get another flashlight more suited to your needs.
Hi Jack :slight_smile:
Buy yourself another light.
If you walk the forest in the dark, you certainly want to see where you put your feet!
One thanks for the headsup.
