Folding knife geometry
Anyone know if there is a preferred stop pin to pivot arraingement? I was looking at my knives and noticed the stop in on the Enlan EL-01 is ahead of the pivot point [looking down on the blade spine]. OTOH, the L-05 has the stop pin behind the pivot point [again looking down on the blade spine]. Do different stop points effect how well the knife keeps solid lock-up when in use? Just curious since I didn’t find any info related to the subject.
It’s all down to manufacturer preference I think. It shouldn’t make any real difference.
The type of longitudinal placement you’re referring to doesn’t matter, but the farther the stop is from the center of the pivot the stronger it will be, if all other factors are equal, like material strength, thickness, etc., so wider blade knives would theoretically have a potential advantage.
Most designs that I am aware of will lock at the very top of the blade for that reason, but mostly this doesn’t matter much, because of the weakness to lateral forces, side to side. If a knife gets “tweaked” under force it loses structural integrity.
It’s all mostly theoretical, folders do tend to break if you use them too hard.
You sound like you have some experience with knife design TC.
I’m learning more as I go along, but at the moment I really want to make my own 20cmNavaja.
TC,
Thanks for your insight. The reason I ask about the stop pin / pivot geometry relates to how any cutting [downforce] is applied to the pivot. On the EL-01 the stop pin is ahead of the pivot so the force is against the bottom/front of the pin and against the upper/back of the pivot. That arraingement [as I see it] puts more direct force on the stop pin. The L-05 has the reverse arraingement so the pivot takes more of the loading [if I’m thinking correctly]. As you point out, lateral forces will cause distortion and create side-play. But does the stop-pin ahead of the pivot have an advantage over stop-pin behind the pivot in lessening the distortion / tweaking?
Well, it’s an extra brace up-front for the frame, and that’s good, but all it really does is stop the blade from rotating; the stop doesn’t hold the blade, the pivot pin does. The pivot pin is the main structural element that holds everything together. The stronger the pivot assembly is, the stronger the knife will be. Any flexing is likely do to insufficient tension on the pivot bolt or a loose fit caused by manufacturing tolerances.
The inherent design of these knives is strong enough for anything a small knife needs to cut. The only time any of this would come into consideration is during destructive testing or trying to use them for ridiculous tasks.
If you use them as a knife they should have a good service life, and there is no reason for them to fail prematurely, but if you want to cut down trees or demolish concrete with them they will break.
