Why do Li-ion Batteries die ? and how to improve the situation?
Tesla non secret
Lithium cobalt oxide (LiCoO2)/graphite + vinylene carbonate
Somthing interesting after 1:03.00
Tesla non secret
Is there a coles notes version instead of a long video?
https://www.google.com/search?q=Jeff+Dahn+(Dalhousie+University)
What he’s saying at 1:03 in the video seems to be: Lithium titanate — extremely long lifetime, enough to implant the cells permanently as medical devices, at 4.1v …
the more time you spend at higher voltage, the worse (the battery life); storage at 4.0v can last for years; if they had been charged to and stored at higher voltage they degrade.
Listen on through to the end from that point. Take-home message: don’t keep cells at full charge, and don’t keep them at room temperature—refrigeration prolongs lifetime dramatically, by years.
When thinking/debating about battery specifics one needs to be clear about the chemistry under consideration.
FYI
From the peanut gallery:
“On June 15, 2015 at 10:03am
Antonio wrote:
LiNiCoAlO2 are the Panasonic NCR18650B, they give 2C max current and 3450 mAh capacity. They have a graphite anode. Shortly we should see the same battery with a silicone anode, as they reached max half capacity. Next gen with silicone anode will start at 3900 mAh.
LiMnPo4 batteries are an evolution of LiFePO4, giving higher terminal voltage. From what I know production of those haven’t ramped up. Manganese is not allowing the same 2000 cycles of correspondent iron-based structure.”
Well, then waiting for next gen :D!
I have been told that cold lithium in motorcycle applications won’t work on frosty mornings.
But back to our cells should I store them in fridge after charging as opposed to on the shelf?
After reading BU about lithium battery life and storage voltages I realized that until recently I somehow have ignored this very important thing!
Safety, venting, over-charger and discharge, those yes, a holy bible! But in regards to storage I accepted that they will probably be as good as Eneloops if not better :D!
So, now I have discharged all my unused lithium batteries(that would be ALL of them except those couple of batteries that sit inside the lights at the moment that I might use any day) to 3.84V or lower.
Once my Lii500 charger arrives it will be interesting to see if and for how much my barely used NCR18650B’s have degraded over the two years or so that I own them since they were stored full :D!
Luckily Ive got 30Q’s on their way!
Will be really interesting to see whats happened to the panny b’s veer, i hope your going to post the results ![]()
It will take a while though, I ordered Lii500 but its out of stock and should be back in stock on 10.decemeber and only then ship, so mid-january maybe :D!
EDIT: I just checked, I made an order of NCR18650B’s in september 2013, I remember that there were China post issues related to temporary ban on lithium battery shipments so Wallbuys had to reship them, not sure when I received them, but lets assume that its been 2 years give or take one month since I own them and have kept them mostly fully charged at room temperature.
