Dedomed XML-U2’s on sinkpads. The driver has been modded so it’s putting out about 3,500 lumens. It also had heatsinking added under the pill in the form of seven large washers giving it one large heavy pill. Heat transfer is nearly instant. Spring mod and heavier wires were also done. It throws well with the de-domed emitters and has a nice neutral tint. Flawless reflector on this one as well.
Your’s is coming along nicely. I sanded the pill and polished it, ground down the sinkpads to fit. They won’t fit full size with a 6x. I also re-flowed the emitters onto the sinkpads and now they are soaking to de-dome. That should take another hour or so. Then I’ll clean them up and epoxy them in place. Tomorrow night, after the epoxy is fully dry, I’ll wire it up, do the spring mod, mod the driver and add heatsinking.
