I would like to permanently remove the next mode function of a driver to only use it at full power.
I saw in other topic that I have to short circuit the capacitor to do that. However, I cannot locate it on my flashlight driver.
If I bridge the two caps I will reduce the memory delay depending on the bridge quality (resistance).
Because I need to reduce memory delay under 10ms can I use pencil ?
Do you know if I remove caps the circuit will only work at full power ?
