This is the fourth and final rebuild of my Boruit Z001 7 x XML. Here is a link to the original build thread.
https://budgetlightforum.com/t/-/25916
Good to here some winner stories every now and them. The 5 amp driver on my AA powered HD2010 lasted 5 minutes in a run time test. Where did you get your 2C leds from?
Your light missing a reflector should have the leds dedomed and 10 degrees TIR nestled up to them.
Thanks MRsD.
I got the XM-L2 U2 2C from both IOS and RMMs store. I also used them in both my MTG/XML mods.
I also thought about TIRs. What do you think, a cluster of triples or a gaggle of singles?
I just don’t know how I could make an opaque lens shroud like your contest light. I don’t have the tools to accomplish it.
You probably dont have enough room for singles as the TIR's that I know are about 22mm in diameter.
Nice..
I dont dare to think about all the lights that ive been done with. Finished, perfectly happy with the mod. And then, mod it again within 3-6 months just to improve it, or make it suit my collection/ be different from other lights Ive got.
Not sure why you took out all the 7 emitters though. If you wanted something "2C" tint, you could have just used 5 of the U2 1A and a WW emitter in the middle ("7" or "8" tint) In lights with one or several emitters in the middle tint mixing is a must do.
Oh well, next time.. Btw. Do you have off time memory?? Are you running that whiny phase correct firmware?? Have you optimized the modes for that particular light? :D Im just looking for excuses for you to not have it in its final stage. ;)
Im impressed if you are not doing a little tweak to it again within 12 months... There is always something.
Im really liking that mod and the size of that light. Great work and thanks for sharing.
Edit: Btw, you know there are 9V MT-G2s? If you can get a hold of one. Putting one 9V MT-G2 in the middle of a 7 XM-L reflector would solve your problem.
I had to pull off all the 1A emitters except the center one because the footprint of the six LED reflector is different than that of the seven LED reflector. I damaged some of the Noctigons trying to get them off (heat and pliers), and they all need to have the adhesive scraped and sanded from them. I didn’t have the time or energy to do that today, so I used the 2C that I had handy. Plus I needed a bit of a change.
I was thinking of using 3 x 1A and 3 x 2C, but with six emitters the placement wouldn’t have been uniform and I didn’t want a cockeyed tint in the beam profile.
I got these from RMM. I’ve got five modes 100-50-20-5-2% with off time memory. I’ve not had whining in any of my FET drivers.
Really nice job on the light! What light donated it's reflector?
That is just a sweet light you have made there. Such a shame about those beast drivers. Does everybody agree that they croak sooner than later by now?? You sure are a persistant man. My hat off to you :-)
I dug around in my boxes and found some Carlco single optics for XM-L2. I can easily fit five 20mm optics around the edge and a 26.5mm optic in the center. I’m just thinking…it would certainly be a fussy job.
The emitters should fit fine without de-dome. Besides to make it fit, does a de-domed emitter in an optic really make any difference as in a regular reflector?
I cant speak for XML's dedomed in tir's but have put dedomed XPG-2 leds behind XML tir's and apart from the beam looking a little odd white walling increases throw dramatically. This is what I did with manxbuggy's light and he was stoked with it. He has some beamshots here somewhere.
I had my Boruit out for a test spin last night and it's everything I want. There was no point in taking beam shots because there is so much light all beamshots of my large multi emitter mods look the same with my ipad camera. Basically, everything in the frame is fully illuminated, and that's what it's like in real life.
Dropping down one mode, from 100% to 50%, the output drop is barely discernible to my eyes, but there is better economy in power consumption.
So basically, high mode is great for showing off, but 50% is still in show off mode with better heat and power management.
I decided to see what the the light that donated the reflector for my mod looked like when run as a mule.
A close to the wall beamshot looks very interesting.
Congrats on the long mod. Good thing it's a hobby, it'd be a $800 flashlight otherwise.
Do you have an Ultrafire 602c? Try the reflector on the Rustu. 6 @$4 ea. gets expensive but in for a penny...
They're only 17.9mm and the beam is floody but surprisingly nice for it's size. Probably need to mill wire clearance for 16mm stars.
I don't know if it will ever happen, but I'm thinking about it.
Very nice build! I'd give you a thumbs up smiley if there was one!
Just tried some Samsung INR18650-20R and I’m getting 4A per emitter.
Must get hot fast then :-) Nice!
I'm not sure if this will fit.
I have some of those. Unfortunately they’re way too small (51mm) I think the one I’m using is at least 67mm.
