Boruit 3X XM-L T6+2R5 LED Headlamp Torch outdoor activities 18650+AC/Car Charger Only $19.90
CREE LED Headlamp
Model of LED: 3x CREE XM-L T6+2x XPG-R5 LED
Output bright can come to max 5000 lumens [lm]
Internal wiring applies the high efficient booster circuit, working voltage is wide and can utilize the batteries in the largest extent
Waterproofing design
Adjustable base is provided for each head lamp, with back and forth inclination
One button switch : 1x Cree XM-L T6/ 2x Cree R2/ 3x Cree/ Flashing
Model of Battery required: 2x 18650 3.7v
Color: Black
Dimension : 83 x 37 x 58mm
Weight : 219g
18650 Travel Charger:
Smart charger can charge for 18650 Li-ion batteries, two at a time
LED indication for Power On / Charging / Full charge
AC power input ,Stabilize charging mode
Low voltage stabilize
Model: HW18650-A
Input: 100V-240V~50HZ-60HZ
Output: DC 4.2V, 650mAh Size:8.4 x 4.6 x 3.3 cm(L*W*H)
Color:Black
18650 Rechargeable Battery:
Suitable for Flashlight Torch / Headlamp
Capacity: 3000mAh
Voltage: 3.7V
Car Charger:
Input: AC100v-250v 50-60Hz
Output: DC 4.2V±0.5V
Package Contents:
100% Brand New
1 x Boruit T6+2R5 CREE LED Rechargeable Headlamp
2 x 18650 Battery 3000mah
1 x 18650 Travel Charger
1 x Car Charger
