Free Shipping Worldwide at Exduct
In the latest newsletter from Exduct, I was shocked to find that they now offer free shipping worldwide.
Some of the products in the newsletter can be found here:
http://www.exduct.com/special-limited-products
I can't link to the newsletter without revealing my real name, so I took a screen shot instead:
I’ve ordered months ago from exduxt, it was free shiping :wink:
I knew that! I was just testing you... :X
That is no excuse for u to buy more knives! 0:)
With this Enlan EL01, here they offer it with tools, do I need the tools? $17 knife, $30 for the tools? Ive been considering the EL01 from FT, but I dont really want to deal with them, so Im glad theres an option for that here, but now a new issue, maybe. Do these come loose so often Id need the tool handy (alternatives to the tools on offer)? I bought my son a a Benchmade 3 years ago I never need to adjust. I can flick the blade out with my wrist, yet it holds delightfully closed.
Thanks for the head up on the source. I seem to recall them bieng mentioned, there was an issue, cant recall now, but they have Genuine Enlans, while FT might be selling fakes.
Aren’t there 2 enlans el-01 for 27$ anymore?
Filament,
I have several EL-01s and none have had the pivot loosen over time. As to adjusting the Enlan ‘delta’ pivot screw you can use a drill chuck or as I did make a custom adjustment tool. I used a steel roll pin from a hardware store and a hacksaw blade to cut notches matching the screw arms. BTW, best bang for the buck improvement is to replace the stock pivot washers w/ phosphor bronze washers.
Sometimes the blade on the Enlan EL-01 models need adjusting or to strip for cleaning. Exduct will tighten the pivots so that customs don’t “confuse” them with a gravity knife so the blade may be a bit tight. The earlier types had a pivot pin with three holes in it and could be adjusted fairly easily, the newer models have a triangular shape on the pivot pin and can be a real pain to adjust.
Exduct had these tools made for ease of adjustment and servicing.
The triangle shape on the newer pivot pin can be gripped by a drill chuck (I bought a new keyless one from ebay for about £3) tighten the jaws down and turn the chuck, it’s a bit fiddly but a lot cheaper than the tool.
I’m a sucker for having the right tool for the job and even I have resisted them.
The two in one set is a good deal, the satin plain blade with black scales and the satin plain blade with khaki scales, everybody needs more than one EL-01. :bigsmile:
Thanks for the info. Now I’m trying to find a way to tell my wife that I also have an addiction to knives :~
Edit : found. “And it would be annoying if the knife would fall out of my pocket during the walk with the dog in the evening and I can’t find and pick it. So I need more flashlights”. 0:)
Thanks Gurthang and 8steve88. I have no plans to buy enough of these knives to warrant $30 in proprietary tools for them.
Im dubious of the need for PB washers as they have issues too, galvanic corrosion unless used all the time. Cheap nasty fake ‘teflon’ which the cheap knives have, is not Teflon which is what the confusion about Teflon seems to be mired in. Teflon is great if done right. Then theres the nylon used in earth moving equipment (Nylatron or something) which I believe is also used for washers in high end knives (self lubricating, and rock hard). But yes in these cheap knives, I guess the PB would be a major upgrade.
Sorry OP, back on track…
How do you rate the OP listed Sanrenmu v Enlan?
Drool…
Love the blue handle. Wish it came in the 763 with axis lock and blue G10…but still can’t resist this 7063 version. Interesting that without axis lock, the clip is reversable for tip up or down carry. Purdy.
Might buy another pair of those 710s.
Those 612s are $6.79. Beautiful. Better yet, not from FT. 8) I’m getting one, broken wallet or not. Going to my keychain.
Not sure the previous price but weren’t they sold for around $15 before?
I have one in blue and pictures really don’t do it justice, as you say “Purdy”. Without the Axis lock it is just another linerlock but a very good one, smooth and quick. I have the aluminium LB-763 as well and prefer that but the colour on the newre linerlocks is superb.
I have nearly the full set of Enlan EL-01’s and have converted most of them to phosphor bronze washers of a larger diameter as well as smoothing the blade and washers with 1000 wet/dry then a metal polish and a polish of the pivot itself and inside the blade pivot hole, it makes them a lot smoother, but then I do like tinkering with all my knives. I’ve noticed when measuring the thickness of the installed washers that all the large Enlans have 20 thou worth of washers each side of the blade no matter what the original materiel, it’s usually brass and phosphor bronze on the lock side and teflon and phoshor bronze on the solid side with the phosphor bronze always next to the blade. I can get Nylatron washers in the same sizes as phosphor bronze but prefer the metal ones. I think next time I order I’ll include some Nylatron as well.
As to the original topic, SanRenMu are knocking Enlan badly with their new ranges, they have stepped up a gear in quality, Enlan still do a superb knife for what you pay but SanRenMu are ahead on quality. Out of the last 10 knives I’ve bought 9 of them have been SanRenMu’s. The new 7010 series that replaced the 710’s seem to be coated at the factory for corrosion resistance and the oil that they use has strange smell but once wiped down all is good.
At the $7.99 price from Exduct or the ~$8.50 price from FastTech they are amazingly good for the money.
