mortuus
(mortuus)
1165
there is nothing strange, a high drain 26650 20A+ costs like 7,8 euro on nkon.nl… thats legit price…
Skylight
(Skylight)
1166
Mateminco is offering the last pieces of the Mateminco MT07 in purple, pink and orange. If you like these colors and can order on Taobao you should get them now as they are a limited edition / custom colors and Mateminco won’t make any more once they are sold out.
The link is: https://item.taobao.com/item.htm?spm=a230r.1.14.4.b2a84f31VAn3Ji&id=601400371114&ns=1&abbucket=1#detail
Here is a picture of them, taken from the reviews on Taobao.
Thro
(Thro)
1167
Just bought a Sand 4000k for 39.60 euro (including shipping and tarif insurance)
any update on a Alu XPL HI version ? wouldn’t minde getting a olive green XPL HI to add to the collection
I already received my Olive Green MF01 Mini 6500K. I really love the light and Anduril firmware. I will post pictures as soon as I can.
Dr.Phillip
(Dr.Phillip)
1169
Do you own a BLF Q8 or any other well recognizable flashlight? Could do a side by side photo comparison?
And here is the view of the AUX LEDs. I increased the brightness of Blue and Purple to make it more prominent. There are 4 trimmer resistors one for each color (red, blue, green and purple).
JordanZHP
(JordanZHP)
1172
Is it easy to figure out which trimmer resistor adjust each color? Do you just use a screwdriver?
Yes, it is easy. I used a small flat head screw driver. First you enable the high settings for the AUX LED, then turn clockwise to increase the brightness.
Here are some pictures with other items/flashlight so you can visualize the size.
Astrolux S43, MF01 Mini, Flipside Wallet, Leatherman Wave
Nitecore TUP, Convoy M3, Astrolux S43, MF01 Mini, Astrolux MF01, Convoy L6, Astrolux FT03
alkiax
(alkiax)
1175
I’m new so I’m curious what is the point of changing the aux leds. I don’t even know what they are supposed to do. Has anyone that received theirs taken any outdoor pictures?
Aside from serving as an eye candy, they can serve as an indicator if you are in lock out mode or normal mode since you can set it differently. I have mine in blinking mode in normal mode and in low mode in lockout mode.
As for adjusting the brightness of individual AUX LEDs, out of the box, they seem too dim for me, so I adjusted it according to my preference.
alkiax
(alkiax)
1177
ok. That makes sense. For a second I was thinking they were being used to tune the temperature of the main light or something. Thanks
Please note what Lexel wrote:
Translated with google:
The Aux LEDs can be made a lot brighter by trimmers, but somebody in China has messed up the values of my calculation table
End of song LED resistance 1kOhm poti 100kOhm, poti to 50kOhm as it comes out of the band
95% of the poti almost does not happen, then it gets incredibly fast bright up to 10mA alone in green
because the driver Bauer said that only this combination in low mode lights up all 3 colors instead of simply turning the green potentiometer a bit (to equalize the falling voltage across the combined series resistor of the 3 colors) and forwarding the pot position to the production
JasonWW
(JasonWW)
1179
Everything is explained here.
Loneman
(Loneman)
1180
Mine has arrived and it's fantastic. I double-clicked my D4S to turbo, shone it on the ceiling then did the same with the Mini. I was a little disappointed that the Mini looked to be the same brightness but guessed it was due to the wider hot-spot, then something told me to double-click again and BAM! Even brighter! I'm using Milicel P42a 21700's and Keeppower 5200mah 26650's in the C4s, btw.
I went with the 5000k tint, but to my eyes it has a green tinge when compared to the XPL-HI V2 3A 5000k's in my D4S, I'm sure that I'll get used to it in time.
Now, I'm off to fiddle with the Aux LED pots now, wish me luck.
SKV89
(SKV89)
1181
I do not see those color options in that link.
Skylight:
The link is: 淘宝网 - 淘!我喜欢
No, thats the “Mini”-Thread.
Look at the markings on the board.
Low is red
high is green
D1 blue
D2 Pink
(as Lexel wrote: Astrolux MF01 Mini / Mateminco MT07 | Taschenlampen Forum)
Skylight
(Skylight)
1183
They don’t write the colors but it’s the third option from below ‘custom colors note color’. You would need to contact them, ask what they still have and order with this option then. There are no pictures from the seller just customer reviews.
Tubercle
(Tubercle)
1184
So, is it brighter than the d4s for those that have both? Based on the video I posted earlier, it wasn’t.
