FireFlies NOV-Mu Group Buy
21*Nichia E21A R9080 5200lm CRI98 AUX LEDs Anduril Simple UI Flashlight
Our shipping
Note: speed of delivery varies from country to country.
Group Buy Price: $8-.99
Freeme's Coupon: Request in this thread
Features:
Battery reverse polarity protection
+/-1C factory calibrated thermal accuracy
Optimized low parasitic drain (if aux. LEDs disabled )
Water resistant IP66
Removable Metal pocket clip
High performance copper thermal sink for LEDs
High Conductive Silver-Plated 17530 BeCU Bypassed Springs
Heavy-duty removeable magnet in tailcap
6-pin programming pads on driver board for hobbyist customization
Specifications:
- LED - 21x Nichia E21A High CRI98 emitters
- Max output:
- Nichia E21A SW455 D240 4500K version --5200 Lumens
- Nichia E21A sm2050 D160 2000K version --3500 Lumens
- 4x RGB auxiliary LEDs
- Durable electronic side switch
- High efficiency 6A constant current buck driver (>90% efficiency) with FET Turbo
- True 2A USB-C in-built smart battery charging capability
- Ultra-clear AR coated optical glass lens
- 1x 21700 lithium battery, or18650 battery with included adapter (battery not i ncluded)
- Operating range 2.7V to 4.3V
- Dimensions
○ Head Diameter - 32mm
○ Body Diameter - 26.5mm
○ Length - 114mm
○ Weight - Approx. 108g without battery
- 6063-T6 aluminium construction with stainless steel bezel ring
- Durable type-III hard anodized coating
- User Interface
○ Latest Anduril2 open-source firmware with Simple and Advanced UI
■ Simple UI: 6A maximum regulated current
■ Advanced UI: 6A maximum regulated current with FET Turbo
○ Fully configurable modes of operation: smooth ramp to stepped ramp
○ Fully configurable auxiliary LED effects and modes
○ Automatic, manual, or hybrid memory modes
○ Continuously monitored battery current, voltage, and temperature with 2.8V battery cut-off
○ Ability to customize highest and lowest output levels
○ Ability to customize thermal regulation (50C by default)
○ Large variety of beacon, SOS, tactical strobes, and special effects including:
■ Candle flicker, thunderstorm, bicycle light, sunset timer and more!
○ Readout of battery voltage, internal temperature
○ Electronic factory reset capability
○ Lock-out mode capability
Operation:
The NOV-MU flashlight features the advanced open-source user interface firmware, Anduril2. For full details of operation, please see the detailed manual: http://toykeeper.net/torches/fsm/anduril2/anduril-manual.txt
At the first glance of the UI , most fresh users will feel confused with the UI, But in fact , you can operate the light as easy as other common flashlights. Just in case you want to try more functions , you need to spend some time to read the manual . If you do not need the advanced features, just do not use it.
Anduril2 has two different operating user-interfaces.
1. Simple UI -- Stepped 5-mode ramping default (Easy to operate for all fresh users)
2. Advanced UI (need to spend some time to read the manual carefully to try more functions)
Enter advanced UI to unlock all the features available. It is simple to switch between Simple and Advanced UI.
Note: Anduril2 has the capability to adjust battery voltage correction and temperature calibration. The NOV-MU flashlight comes with 1% voltage accuracy and +-1C temperature accuracy from the factory and does not need to be calibrated by the user.
Package Included:
1 x Fireflies NOV-MU 21*Nichia E21A Flashlight
1 x Clip
1 x Soft Diffuser
https://1thedeals.com/blf-flashlight-group-buy/
