FREEME ✌ HAIKELITE HK90S G90 5000lm 1100m USB 3*18650 Flashlight Group Buy - ALIVE
HAIKELITE HK90S (2022)
HK90S G90 5000lm (CW) 1100m 3*18650 USB Rechargeable Flashlight Group Buy
Group Buy Price: $51.95 (usual $79.89)
Freeme's Exclusive Coupon: F38585
Can't wait for our reply??
Price: from $54.95 (usual $79.89)
Coupon: BG4B9158
Specification:
Brand HAIKELITE
Model HK90S
Lamp beads G90
Lumen 5000LM
Range 1100M
Color temperature 6000-6500K (cool white)
Waterproof grade IPX7
Material 6063 aluminum alloy
Surface treatment Military grade three hard anodized
Lens Tempered glass lens, anti-reflection purple coating
Colour Black
Battery Three 18650 power batteries (not included)
Spring Ultra-low internal resistance copper alloy silver-plated spring
Charging time 3000mAh 3 sections 18650, about 3-4 hours
Charging Type-C bidirectional fast charging port, the switch lights up red when charging; the switch lights up blue when charging is complete.
Dimensions 147mm (total length) x 60mm (head) x 50mm (tail) x 46mm (body)
Weight 361g
Features:
  1. Stepless dimming: when it is turned off, press and hold the switch for stepless dimming to increase the brightness, release the switch and then press and hold to change the dimming direction and reduce the brightness
  2. Extremely bright: when it is turned on, double-click any gear to enter extreme bright. When the temperature of the flashlight reaches 55°C, there will be a temperature control protection function, and the flashlight will quickly drop to about 2000 lumens. If it reaches 55°C in the high-brightness gear, it will Slowly drop to about 3000 lumens, it will continue to brighten, and the torch will rise to the high-brightness gear when it is lower than 45 °C.
  3. Strobe: When turned on, double-click - extremely bright and double-click again to enter burst - double-click again to enter S0S mode - double-click again to enter super flash, click to close at any gear
  4. Battery power display: when the battery is lower than 3.2V, the blue light flashes, when the battery is lower than 3V, the red light flashes, and when the battery is lower than 2.8, it will automatically shut down
  5. Charging indication function: red light when charging, blue light when fully charged.
  6. Mobile phone charging indication: The blue light is always on when charging.
  7. Charging power: charging 5V 3A, 9V 2A, Huawei SCP5V 4.5A, two-way fast charging.
  8. Stepless dimming/gear mode switch: When turned on, triple tap to switch between stepless dimming and gear mode.
  9. Gear mode: first gear 200 lumens, second gear 1000 lumens, third gear 2000 lumens, fourth gear 2800 lumens, double-click to extremely bright 5000 lumens, double-click again to enter strobe.
  10. Lock mode: press and hold for three seconds to enter the lock function when it is off, and unlock it when it is turned on for three seconds.
Package included:
1x HK90S Flashlight
2x Waterproof O-rings
1x Product Manual
1x Carrying Strap
1x Type-C cable
1x C-C reverse charging cable
Images:
Reserved.
So G90 is the emitter name?
I think that's new to me.
Also, nice looking flashlight!
That is definitely an SBT90. Did we need another soda can SBT 90 light? This feels a little late in the game. (Haikelite is always late in the game, but also the products are solid.)
It's not Luminus.
This one is 3*21700.
I don't think there's a whole lot of those yet.
My bad, it is 18650.
Pics from Chinese buyer.
Lumintop have one model on this led odl20c v2 (GT90 LED, or 9090 LED)
https://www.nealsgadgets.com/products/lumintop-odl20c-v2-flashlight
It's SBT 90.2 copy
G90 and GT90 are the same thing?
Can't really tell, because I heard different names on this led, but physically it looks identical
Lumintop odl20c v2 (left) vs HAIKELITE HK90S (right)
