FREEME ✌ NEW IMALENT MS08 8*XHP70.2 34000lm 738m 21700 Flashlight
IMALENT MS08
8*CREE XHP70.2 34000lm 738m 21700 Flashlight Deal
Our Price: $2--.99 (usual $429.99)
Freeme's Exclusive Coupon: Request in this thread
Can't wait for our reply??
Black Friday Price: $294.99 (usual $429.99)
Features:
  • IMALENT MS08 Brightest EDC Flashlight
  • Utilizes eight pieces of American CREE XHP70 2nd LEDs. The lifespan is up to 50,000 hours with maximum output of 34,000lumens.
  • Powered by three rechargeable 4000mAh 21700 Li-ion batteries
  • Instant turbo output by double press the side power switch button while triple press the side power switch button, can get lowest output
  • Product size:74(head diameter)*51(body diameter)*125.5(length)mm
  • Net weight:651g(battery excluded)
  • High efficient circuit, can be constantly on at 10,000 lumens
  • Built-in thermal control module, and equipped with a fan powered heat shield,will automatically adjust the brightness output according to the working state and outer temperature, keep using comfortably.
  • Combination of toughened ultra-clear mineral and anti-reflective coating glass
  • Aluminum OP reflector
  • Aerospace-grade aluminum alloy body,wear-resistant Type III hard-anodized surface treatment .
  • IPX-8 standard waterproof(2 meters submersible).
  • 1m impact resistant. Operation instruction
Specification:
BRAND IMALENT
PRODUCT CODE MS08
LED TYPE 8 pieces of American CREE XHP70 2nd LEDs
ATTERIES REQUIRED Battery pack(21700-4000mAh*3)
LUMINOUS FLUX Up To 34000 Lumens
RUN TIME Up To 30h
INTENSITY 136000cd (Max.)
DISTANCE 738m (Max.)
OPERATING MODES
Turbo / High II/ High I/ Middle II / Middle I / Middle Low / Low /
OUTPUT AND RUNTIME
Turbo output : 34,000~10000 Lumens;Run-time : 45s+53min
High output: 10000lumens; Run-time: 60min
Middle II output : 5000 Lumens;Run-time : 1h30min
Middle I output : 2000 Lumens;Run-time : 4h50min
Middle low output :700Lumens;Run-time :19h
Low output : 300 Lumens;Run-time : 30h
MEASUREMENTS
125.5mm(length)*74mm(head diameter)*51mm(body diameter)
WEIGHT
651g(battery included)
IMPACT RESISTANCE 1m
WATERPROOF IPX-8 standard waterproof
ACCESSORIES
Charger, O-rings, Shoulder straps, User manual
Package included:
1 x IMALENT MS08 LED Flashlight
3 x 4000mAh 21700 Li-ion Batteries
1 x Fan Powered Heat Shield
1 x Screw to Fix The Heat Insulation Shell
2 x USB Cable
2 x O-ring
1 x Holster
1 x Manual
https://1thedeals.com/blf-flashlight-group-buy/
Reserved.
Reserved.
All replied.
I’ve ordered the light,thank you.
Thank you for your continued support, Theodore41!
Alternative store.
https://1thedeals.com/product/imalent-ms08-8xhp70-2-34000lm-738m-21700-flashlight-nl/
Any compatible handle for this light...
I don't see any mounting point for MS08.
Please freeme,can you check with Banggood if there are out of stock,and when they can restock?And this,because I have ordered at 11/26 and I see the same notice when I try to check my order.ie we are out of stock.
Sorry for waiting. Let me find out with BG again.
