Skilhunt H03 & H03F CREE XM-L2 U4 1000lm Headlamp
H03 NW sample was provided by GearBest.com for review purpose.
Overview:
Brand: Skilhunt
Model: H03
Price: $51.90 (cool white) / $52.90 (neutral white)
Emitter: CREE XM-L2 U4 Cool White/ Neutral White
Brightness: 1000LM (manufacturer rated), 1200lm LED lumens
Mode: 4 brightness level modes with 8 levels to choose from + 3 flashing modes
Peak beam intensity: 3,800cd
Lens: Beam surface TIR lens
Mode Arrangement: L1/ L2, M1/ M2. H1/H2, T1/ T2 (see diagram).
Mode Memory: Yes
Battery: 1x 18650 / 2xCR123A
Net Weight: 44g/ 1.55oz (without battery)
Size: 99.9mm / 3.93 inch, 23.5mm / 0.93 inch, 21.6mm / 0.85 inch
Waterproof Standard: IPX-8 Standard Waterproof
First Impression:
Package contains:
- Skilhunt H03 headlamp
- headband
- lanyard
- pocket clip
- 2x o-ring
- rubber pad (to fill up the empty space if you choose not to install the magnet)
- user manual
- warranty card
Close up look:
Weight:
User Interface:
Mode S1 (dual frequency strobe), S2 (beacon), S3 (slow flashing) and location indicator red LED on 1.5s press.
Performance: Tailcap Amperage Readings
1) Tailcap measurement:
T1: 2.55A
H1: 265mA
M1: 119mA
L1: 4mA
L2: 0.03mA(lowest brightness):
Test conducted with high drain Samsung 30Q 3000mAh 15A @4.18V
Parasitic drain:
H03 - 31.4μmA
H02 - 22.2μmA
Performance: Runtime
Battery is measured at 4.17V before test. Output value is recorded after 30sec from start (FL1 Standard). Consistent output level was observed for 2 hours after Turbo stepdown. Low voltage indicator kick around 2hr 48min mark for double flash (below 3.3V warning), and triple flash around 2hr 56min mark (below 3.0V warning). Flashlight auto shutdown at 3hr 10min mark, with 2.74V left in the battery.
Beam Profile: Tint
Beam Profile:
Beam projected 65cm / 25.6 inch away from blank wall.
Side-by-side comparison of H03 (left) and H03F beam (right). You could see a smooth transition between hotspot and spill* when diffuser lens is placed in front of LED.
*not captured on camera due to limited dynamic range of the sensor.
Edge of H03F beam will be blocked, when the swing open diffuser lens to extreme right.
Boom!!! 1200lm.
Beam Profile: Outdoor
Throw distance increases with the help of its lightly textured OP reflector when diffuser lens is swung open. Foreground is noticeably brighter, as the beam is concentrated to the front. Shadow cast by the lens hinge (right edge in above pic) is less prominent when beam is projected at far distance.
Just in case you didn't get what I meant. I was holding the headlamps in up right position when the outdoor beam shots were taken.
Operational Temperature
The hottest zone is located somewhere near neck of the flashlight at 52°C/125.6°F. Whereas temperature at body tube and tail section are more uniform, between 43°C/ 109.4°F +/- 2°C/35.6°F after running it for 3mins.
Note: flashlight output has been overpowered by my studio strobe lights, that is why you do not see the output (at this camera angle) even it is being switched on.
PWM (Pulse Wave Modulation)
Skilhunt H03 does not show any visible PWM in our test (JET-1 MK on the left).
Size Comparison:
Side by side comparison with Skilhun H02 (extreme left), Skilhunt H03 (2nd from the left), Skilhunt H03F (second from the right) and Fenix HL10 (extreme right).
What I Like About Skilhunt H03:
- Coming soon
What Needs to Be Improved:
- Coming soon
Our Skilhunt H03 Rating
| H03 | H03F | |
| Power | ★★★★✩ | ★★★★✩ |
| Ease of Mod | ★★✩✩✩ | ★★✩✩✩ |
| Price | ★★★✩✩ | ★★★✩✩ |
| Overall Value | ★★★★★ | ★★★★✩ |
| Recommended |
Conclusion:
Coming soon
