Weltool W4 Pro (2022)
Weltool W4 Pro LEP 568lm 3394m 21700 Thrower Flashlight USB Rechargeable "Flashlight Deal"
Exclusive Deal: $LOW (usual $460)
Freeme's Exclusive Coupon: F56055
Specification:
| Brand | Weltool |
| Model | W4 Pro |
| Material | Aluminum, black hard anodized |
| Mode | High/low |
| Throw distance | 3394m 3.4KM |
| Lumens | Low mode 210/ High mode 568 |
| Battery | 21700 rechargeable lithium-ion battery |
| Runtime | 4 hours 30 minutes/1 hour |
| Reflective system | Acrylic convex lens |
| Beam angle | 1.8° |
| Light source | LEP module, wavelength 400-700nm, lifespan is about 10,000 hours |
| Switch | Tail button forward switch, 50,000 pressing life |
| Anti-drop height | 1 meter |
| Protection level | Reaches IP67 |
| Battery | Use 1 21700 Li-ion rechargeable battery (included) |
| Weight | 336±2g (without battery) |
| Dimensions (±0.5mm) | (Head diameter) 60.5mm, (Body diameter) 27mm, (Length) 198mm |
Features:
- The Weltool W4 Pro is an upgraded version of the W4, a LEP flashlight with a throw distance of 3712yd! The light intensity reaches 2,882,000 candela, and the luminous flux is 568 lumens.
- High-efficiency drive circuit, no noise and no flicker.
- With temperature control protection: When the temperature of the flashlight is too high, the flashlight will automatically reduce the brightness to prevent overheating
- With low voltage prompt function, polarity protection, battery over-discharge protection.
- It uses a 21700 rechargeable lithium-ion battery, uses a customized LEP light source, and then passes through the lens reflection system to form a dazzling beam. Two brightness modes, high and low, are easy to operate.
- W4Pro has almost no spill, suitable for field search, sea rescue, long-distance indication, etc. It is specially designed for special lighting.
Package included:
1 x Weltool W4 Pro LEP Flashlight
1 x 5000mAh 21700 Battery
