One or more of their lights use a simplified version of Anduril that gets rid of the adjustable ramp levels.
I was thinking, if this model has full Anduril you could raise the ramp level to the point before it goes blue and then just not ever use Turbo. This way you can use max safe brightness.
There’s also a chance your mcpcb might not be making good contact to shed the heat fast enough. If there’s a spec of dirt or a high spot under the star, that could cause it to go blue.
