I thought that its a common sense even for non-flashaholics to know that batteries go with positive end first(well, at least around here all flashlights that Ive seen in my life have been that way and otherwise you could always look at the springs and markings), obviously not this time, so its driver is fried - I put batteries in it but all it give is faint LED glow+smell like burnt plastic.
It came with reverse polarity protection by default via plastic ring/spacer at the positive end, but it broke and fell out quickly, so I removed it and it wasnt problem for me, until I gave the light away...
Any one modded/repaired theirs - how to remove the driver, at first look it seems like press-fit? In case its press fit, do I have to trash the lens and reflector+LED to get the old guts out?
What should I go for? What kind of choice I have in regards to available drivers for this format? NiMh/Li combined or just shoot for 2x14500 pocket thrower with XP-E2?
Only partial help. I removed the driver from my Jetbeam BC10, should be similar construction but driver came out of the bottom of the head after a little persuasion. If it is the same as the BC10 you can’t access the driver from the LED side as the LED side is separated from the driver side. Could possibly find a driver of similar size to replace it as I never measured mine as I was doing an LED swap and had to remove the driver due to the wires ending up too short.
EDIT:
I think after I opened the head up I sorta pushed the driver out from the top through the LED wire holes with a thin pick type tool. Possibly also twisting(unscrewing) the driver as well using the gold contact legs as a point of pressure. Hard to explain something I did at 3 in the morning.
