I made some of these for charging my LGs 3000 because I prefer separate chargers for each chemistry(3.6,4.2,4.35V) rather than one universal,because there is a possibility that soon or later I will forget to change voltage setting(and that's not good).Miller chargers have really nice cases,so I used ML-103 case.Two MCP73831 chips(one 4.2V,one 4.35V) do the job.Red DC 5.5x2.1mm socket and 4.35V warning sticker for easy recognition.Red light when the battery is charging,green when battery is fully charged.
Price:10$/piece+shipping
Extra 20AWG 5Amp rated USB to 5.5x2.1mm cable:2$+shipping
EU-only
Shipping cost:
0-50g:1,5$
51-100g:2.5$
101-250g:5.5$
Note:do not use cheap(bad) ac/dc adapters(Ioncell,genuine cell phone/tablet,or similar chargers are recommended) ,and cheap usb cables(I measured 2ohms total resistance on 1$ cable from fasttech!).
PCB is completely new,with large copper planes for better cooling,for accuracy and other specs check IC datasheet,max. 1Amp charging current,battery length-same as 4.2V ml-103 miller charger.
I want to know how accurate your charger is not what the specs say…there were problems with these charging circuits in former time. Also charging current differs…
Measuring and testing them will enlighten us.
Have you adjusted the 4.35V chip to 500mA? Then the cutoff is at 50mA…right?
If you have one which makes reliable 4.37V or so I am very interested if they only make around 4.3 I am absolutely not interested…but maybe others want only charge to 4.3…
Charger is just as accurate as IC datasheet says,I measured 4.33-4.36V,and that's within chip spec(4.318-4.383V).If you're not happy with this,blame microchip designers.
Penumbra asked me will this charger work on PC,well I just checked on my PC and measured current,it’s 960mA which is OK.I’m surprised because I read that USB outputs have current limit(100 to 500mA I think)?
The limits are artificial (eg more hardware is required to limit than to not limit), so lots of PC hardware skips that stuff. The spec calls for negotiation of each 100mA increment or something, I forget - almost nobody implements that! USB hubs are especially notorious. Some PCs also have dedicated high-current “charging” ports.
Thanks led4power. I would like one charger and one lead shipped to Australia. Whats your PP and how much in I assume US dollars do I pay. Also what is the cost with this shipment of your 5 amp driver?Cheers.
Just a quick update on this charger. I've been using the charger for awhile now with the USB connection and it has not missed a beat. According to my uncalibrated DMM it stops charging at 4.34 to 4.35 volts. Slightly higher than my Xtar WP2h. Batteries are LG D1 18650 and Sanyo UR16650ZTA.
