The bulb is rotated 90 degrees from the orientation of the factory bulb. This can be seen by looking at another user's photos on the DX site so I wouldn't have a high/low beam, I would have a flood/throw beam!
The two bulbs I received are not even facing the same direction! Compare the tab orientation and look at the high/low beam deflector in this pic:
I have a burned-out low-beam filament in one of my bulbs so I need a set of bulbs for my scooter now ASAP. With the CNY, anything from overseas is going to be delayed, and scooter bulbs are hard to find locally. And most online sources are much more expensive.
Have you tried pulling both pair apart then putting them back together after switching a peice from each pair? If your lucky switching one end might make both match.
