Agro
(Agro)
16
Thanks for the input.
If BLFers in general would like A-lights with 26650, that could be changed easily.
Personally I EDC lights in a backpack, so for me weight and overall volume are more important than any individual dimension. Larger head doesn’t add much to volume, but can nicely improve performance.
BTW I may draw a near-tube A-light later, still with 21700. I’m not sure, that may be applicable to more lights, but not having actual driver design I was pretty conservative with sizing. But aspheric zoomie should be doable.
Removing powerbank would help as well. That may be a good light, but not an A-light.
It may be useless for you, but is not in general.
I love my D4 and use its Turbo a lot.
On low currents, LG H30 or Acebeam “5100 mAh” (which uses a cell I failed to identify) are the highest capacity 21700. For moderate currents that may be either 48G or Acebeam.
There are uses where Wh/l and Wh/g are meaningless. That is - when you have enough energy. Beyond that every size increase is a waste, regardless of how it improves power density. Personally I love 18350 - runtime is good enough for my EDC, the best cell has good IR and it’s significantly smaller and lighter than 18650. Even DQG Tiny 18650.
Powerbank function may be an excuse for some to go up with the cell size from what they use now.
For others - recharging that comes with it may be a good reason to go down.
I’m a huge efficiency geek. But sometimes less efficient solutions are simply better.
