Agro
(Agro)
6
A3
A3 is a medium-beam EDC light. It has only 3 emitters, producing much narrower beam than A7.
It comes with a 35-36 mm 3-LED TIR lens. This is a common lens size as it fits nicely standard MR16 light bulbs. It shouldn’t be hard to find a good one for a good price. Also, it shouldn’t be a problem to offer this light both with clear, pebbled and frosted lenses.
Performance calculations above assume clear lens, for a pebbled or frosted these would be somewhat lower.
LED choices:
- dedomed Samsung LH351D
- CRI70:
- With fresh Samsung INR21700-30T it should do 3200 lumens and 34 kcd (drawing 14.5A from the battery).
- With fresh Samsung INR21700-48G it should do 2900 lumens and 30 kcd (drawing 12A from the battery).
- With fresh Aspire 18350 it should do 2500 lumens and 26 kcd (drawing 10A from the battery).
- CRI80:
- With fresh Samsung INR21700-30T it should do 3000 lumens and 31 kcd (drawing 14.5A from the battery).
- With fresh Samsung INR21700-48G it should do 2600 lumens and 27 kcd (drawing 12A from the battery).
- With fresh Aspire 18350 it should do 2300 lumens and 24 kcd (drawing 10A from the battery).
- CRI90:
- With fresh Samsung INR21700-30T it should do 2700 lumens and 28 kcd (drawing 14.5A from the battery).
- With fresh Samsung INR21700-48G it should do 2400 lumens and 25 kcd (drawing 12A from the battery).
- With fresh Aspire 18350 it should do 2100 lumens and 21 kcd (drawing 10A from the battery).
- Samsung LH351D
- CRI70:
- With fresh Samsung INR21700-30T it should do 3900 lumens and 21 kcd (drawing 14.5A from the battery).
- With fresh Samsung INR21700-48G it should do 3500 lumens and 19 kcd (drawing 12A from the battery).
- With fresh Aspire 18350 it should do 3000 lumens and 16 kcd (drawing 10A from the battery).
- CRI80:
- With fresh Samsung INR21700-30T it should do 3600 lumens and 19 kcd (drawing 14.5A from the battery).
- With fresh Samsung INR21700-48G it should do 3200 lumens and 17 kcd (drawing 12A from the battery).
- With fresh Aspire 18350 it should do 2700 lumens and 15 kcd (drawing 10A from the battery).
- CRI90:
- With fresh Samsung INR21700-30T it should do 3200 lumens and 18 kcd (drawing 14.5A from the battery).
- With fresh Samsung INR21700-48G it should do 2900 lumens and 16 kcd (drawing 12A from the battery).
- With fresh Aspire 18350 it should do 2500 lumens and 14 kcd (drawing 10A from the battery).
- my dream EDC
- Osram Q8WP driven to 21A for higher throw, but much lower efficiency
- extremely hot-roddy
- needs the 21A to be regulated because Samsung INR21700-30T will kill the LEDs otherwise. That high regulated output may or may not be possible.
- 3000 lm, 64 kcd
- Cree XP-L HI
- CRI70:
- With fresh Samsung INR21700-30T it should do 3000 lumens and 38 kcd (drawing 13A from the battery).
- With fresh Samsung INR21700-48G it should do 2600 lumens and 33 kcd (drawing 10.5A from the battery)
- With fresh Aspire 18350 it should do 2300 lumens and 29 kcd (drawing 9A from the battery).
- CRI80, 90:
- possible, I didn’t do calculations
On the drawing you can see it together with Emisar D1 and Emisar D4
