A1S
A1S (A1 Supersized) is a compact thrower, a bit larger than C8, about the size of Emisar D1S.
Reflector has exactly the same dimensions as Phoenix Electroforms PA11, cut down to remove the rim from the front. Such compatibility enables upgrade.
Phoenix confirmed to me the possibility of cutting the reflector, but didn’t provide me with pricing information, so I have no idea if it’s feasible for the manufacturer to offer such options. I it’s not feasible, I think it would make sense to increase the reflector size to 50 mm outer diameter.
There are many lenses with 50 mm diameter and so other A*S lights would probably use them. Upsizing A1S like that would be better for family uniformity.
  • Not very hot, some variants should be able to sustain its output until battery runs out.
  • parts sharing: it can use exactly the same driver board as A1
  • offered with the following LEDs:
    • Osram Q8WP driven to 7A
      • 990 lm, 220 kcd with cheap optics
      • 1100 lm, 250 kcd with upgraded optics
    • dedomed Samsung LH351D for those wanting higher output (or warm or neutral or high CRI…)
      • With Samsung INR21700-30T or Samsung INR21700-48G (LED driven to 6A):
        • 1200 lm, 120 kcd with cheap optics
        • 1400 lm, 140 kcd with upgraded optics
      • With Aspire 18350 (LED driven to 5.5A):
        • 1200 lm, 130 kcd with cheap optics
        • 1300 lm, 140 kcd with upgraded optics
    • stock Samsung LH351D for those wanting even higher output
        • 1500 lm, 84 kcd with cheap optics
        • 1600 lm, 95 kcd with upgraded optics
        • 1400 lm, 80 kcd with cheap optics
        • 1600 lm, 90 kcd with upgraded optics
    • Cree XP-L HI
      • With Samsung INR21700-30T (LED driven to 5.75A):
        • 1200 lm, 150 kcd with cheap optics
        • 1300 lm, 170 kcd with upgraded optics
      • With Samsung INR21700-48G (LED driven to 5A):
        • 1100 lm, 140 kcd with cheap optics
        • 1200 lm, 160 kcd with upgraded optics
      • With Aspire 18350 (LED driven to 4.75A):
        • 1200 lm, 150 kcd with upgraded optics
    • Dedomed Luminus SST-40 driven to 8A
      • 1400 lm, 170 kcd with cheap optics
      • 1500 lm, 190 kcd with upgraded optics
    • Luminus CFT-90
      • just kidding
On the drawing you can see it together with Convoy C8 and Emisar D1S
Note: there are no technical reasons not to include CRI80/90 LEDs, I just didn’t bother with performance analysis
