A4S
A4S is a high-output light with 4 LEDs and a deep reflector. The reflector has the diameter of the A1S-one.
LEDs:
  • Osram Q8WP LED
    • 4400 lm, 200 kcd with Samsung INR21700-30T with 28A drawn from the battery
    • hot-rod overheating in mere seconds
    • needs the 28A to be regulated because Samsung INR21700-30T will overdrive the LEDs, maybe even kill them
      • is it possible for this driver to regulate 28A for several seconds?
  • dedomed Samsung LH351D
    • not brighter than Q8WP, but much more efficient. High sustained performance
    • 4400 lm, 96 kcd with Samsung INR21700-30T with 19A drawn from the battery
    • 3600 lm, 79 kcd with Samsung INR21700-48G with 13A drawn from the battery
    • 3000 lm, 65 kcd with Aspire 18350 with 10A drawn from the battery
  • stock Samsung LH351D
    • the most efficient variat, but sacrifices throw
    • 5300 lm, 61 kcd with Samsung INR21700-30T with 19A drawn from the battery
    • 4400 lm, 50 kcd with Samsung INR21700-48G with 13A drawn from the battery
    • 3600 lm, 41 kcd with Aspire 18350 with 10A drawn from the battery
  • dedomed Luminus SST-40
    • 5200 lm, 130 kcd with Samsung INR21700-30T with 25A drawn from the battery
    • 4300 lm, 110 kcd with Samsung INR21700-48G with 19A drawn from the battery
  • stock Luminus SST-40
    • 6300 lm, 68 kcd with Samsung INR21700-30T with 25A drawn from the battery
    • 5200 lm, 56 kcd with Samsung INR21700-48G with 19A drawn from the battery
On the drawing you can see it together with Sofirn C8F
Note: there are no technical reasons not to include CRI80/90 LH351D, I just didn’t bother with performance analysis
Alternative:
There are many lenses with 50 mm diameter and so other A*S lights would probably use them. Upsizing A4S to get the same head diameter would be better for family uniformity.
