I felt the same way about my FW3A and its tendency for accidental activation. I recall seeing a post in this forum about using adhesive to install a washer on the tail, so I checked into it. The linked Amazon listing, which I can’t find at the moment, was for a washer that fit the tail nicely, but the inner diameter was very small, so all of the button was still exposed.
I wanted to decrease the contact area of the button via a washer with a larger inner diameter, so I found a bag of 4 washers at Lowe’s and used rubber cement to install the washer. The washer acts as a shroud by decreasing the button’s area and reducing occurrences of accidental activation, but it’s still easy to press when I position my fingers correctly. There’s now a much smaller chance of my accidentally activating the light after simply sliding it into and clipping it to my pocket.
